Author: hnategh
New Revision: 55701
URL: http://svn.stylite.de/viewvc/egroupware?rev=55701&view=rev
Styling dialogs W.I.P.:
- Style projectmanager edit dialog
trunk/projectmanager/templates/default/edit.xet
— trunk/projectmanager/templates/default/edit.xet (original)
+++ trunk/projectmanager/templates/default/edit.xet Mon Apr 11 16:54:13 2016
@@ -7,6 +7,7 @@
@@ -16,6 +17,7 @@
@@ -26,6 +28,7 @@
@@ -34,44 +37,52 @@
<row class="th" height="20" valign="bottom">
<description value="Value"/>
<description value="Project"/>
<description/>
<description value="Elementlist" span="all"/>
</row>
<row class="row">
<description value="Startdate" for="pm_real_start"/>
<date-time id="pm_real_start" class="et2_fullWidth"/>
<description/>
<date-time id="ds[pe_real_start]" readonly="true" span="all"/>
</row>
<row class="row">
<description value="- planned" for="pm_planned_end"/>
<date-time id="pm_planned_start" class="et2_fullWidth"/>
<description/>
<date-time id="ds[pe_planned_start]" readonly="true" span="all"/>
</row>
<row class="row">
<description value="Enddate" for="pm_real_end"/>
<date-time id="pm_real_end" class="et2_fullWidth"/>
<description/>
<date-time id="ds[pe_real_end]" readonly="true" span="all"/>
</row>
<row class="row">
<date-time id="pm_planned_end" class="et2_fullWidth"/>
<description/>
<date-time id="ds[pe_planned_end]" readonly="true" span="all"/>
</row>
<row class="row" disabled="@pm_accounting_type=status">
<description value="Times" for="pm_used_time"/>
<date-duration id="pm_used_time" options="@duration_format" class="et2_fullWidth"/>
<description/>
<date-duration id="ds[pe_used_time]" readonly="true" options="@duration_format" span="all"/>
</row>
<description value="- planned" for="pm_planned_time"/>
<date-duration id="pm_planned_time" options="@duration_format" class="et2_fullWidth"/>
<description/>
<date-duration id="ds[pe_planned_time]" readonly="true" options="@duration_format" span="all"/>
</row>
<description value="- re-planned" for="pm_replanned_time"/>
<date-duration id="pm_replanned_time" options="@duration_format" class="et2_fullWidth"/>
<description/>
<date-duration id="ds[pe_replanned_time]" readonly="true" options="@duration_format" span="all"/>
</row>
<row class="row">
@@ -79,6 +90,7 @@
@@ -154,7 +166,7 @@
@@ -216,18 +228,18 @@
<column width="10%"/>
<column/>
<description value="Title" for="pm_title"/>
<textbox statustext="a describtive title for the project, must not be empty" id="pm_title" needed="1" size="64" maxlength="255" tabindex="1"/>
<textbox blur="Title" statustext="a describtive title for the project, must not be empty" id="pm_title" needed="1" class="et2_fullWidth" maxlength="255" tabindex="1"/>
<appicon src="projectmanager"/>
</row>
<row>
<tabbox id="tabs" span="all" tab_height="280px">
<tabs>
<tab id="general" label="General" statustext="Start, End, Category, ..."/>
<tab id="description" label="Description" statustext="free descriptiv text"/>
@@ -264,7 +276,7 @@
reduces your MTTR. Get your free trial! http://pubads.g.doubleclick.net/
gampad/clk?id=1444514301&iu=/ca-pub-7940484522588532
eGroupWare-cvs mailing list
