Author: nathangray
New Revision: 55727
URL: http://svn.stylite.de/viewvc/egroupware?rev=55727&view=rev
Fix start & end date filters did not filter
trunk/infolog/templates/default/index.xet
trunk/timesheet/templates/default/index.xet
— trunk/infolog/templates/default/index.xet (original)
+++ trunk/infolog/templates/default/index.xet Wed Apr 13 00:52:22 2016
@@ -7,8 +7,8 @@
<date id="startdate" label="Start" onchange="widget.getParent().getWidgetById('enddate').set_min(widget.getValue());"/>
<date id="enddate" label="End" onchange="widget.getParent().getWidgetById('startdate').set_max(widget.getValue());"/>
<date id="startdate" label="Start" onchange="widget.getParent().getWidgetById('enddate').set_min(widget.getValue());return true;"/>
<date id="enddate" label="End" onchange="widget.getParent().getWidgetById('startdate').set_max(widget.getValue());return true;"/>
</hbox>
— trunk/timesheet/templates/default/index.xet (original)
+++ trunk/timesheet/templates/default/index.xet Wed Apr 13 00:52:22 2016
@@ -5,9 +5,9 @@
eGroupWare-cvs mailing list
