Author: hnategh
New Revision: 55733
URL: http://svn.stylite.de/viewvc/egroupware?rev=55733&view=rev
Fix styling for Filemanager:
- Switch Home and Up button position
trunk/filemanager/templates/default/index.xet
— trunk/filemanager/templates/default/index.xet (original)
+++ trunk/filemanager/templates/default/index.xet Wed Apr 13 14:17:30 2016
@@ -48,8 +48,8 @@
<buttononly id="home" statustext="Go to your home directory" image="gohome" background_image="true" onclick="app.filemanager.change_dir('~',widget);"/>
<buttononly id="up" statustext="Up" image="goup" background_image="true" onclick="app.filemanager.change_dir('..',widget);"/>
<vfs-name id="path" onchange="if(widget.getValue() == '') { app.filemanager.change_dir('~',widget);} return true;" size="80" class="address"/>
<buttononly statustext="Tile view" id="button[change_view]" onclick="app.filemanager.change_view" image="list_tile" background_image="true"/>
eGroupWare-cvs mailing list
