Author: hnategh
New Revision: 55755
URL: http://svn.stylite.de/viewvc/egroupware?rev=55755&view=rev
Fix styling for button with only image
trunk/egroupware/api/templates/default/etemplate2.css
trunk/pixelegg/css/mobile.css
trunk/pixelegg/css/pixelegg.css
trunk/pixelegg/less/layout_buttons.less
trunk/pixelegg/less/svg.css
trunk/pixelegg/mobile/fw_mobile.css
— trunk/egroupware/api/templates/default/etemplate2.css (original)
+++ trunk/egroupware/api/templates/default/etemplate2.css Fri Apr 15 14:42:38 2016
@@ -252,9 +252,11 @@
button.et2_button_with_image {
padding-left: 20px;
background-repeat: no-repeat;
- background-position: 4px center;
background-size: 16px;
height: 24px;
+button.et2_button_with_image.et2_button_text {
/* et2_box_widget ###*/
button[id=“cancel”],
— trunk/pixelegg/css/mobile.css (original)
+++ trunk/pixelegg/css/mobile.css Fri Apr 15 14:42:38 2016
@@ -1483,26 +1483,6 @@
.ms-ctn .ms-trigger {
border-left: none;
- EGroupware: CSS with less preprocessor
- included in pixelegg.less since 17/03/2014
- Please do NOT change css-files directly, instead change less-files and compile them!
- font styling
- allowed attributes: font-family,font-size,color,font-weight
- layout_*.less files are Pixelegg template specific
@@ -2066,12 +2046,13 @@
-o-transition-timing-function: linear;
padding-left: 30px;
- background-position: 6px center;
background-size: 20px auto;
/.Button_size_h32_auto;/
height: 24px;
background-repeat: no-repeat !important;
- background-position: center;
background-size: 20px 20px;
background-color: #e6e6e6;
@@ -2085,6 +2066,9 @@
background-image: -o-linear-gradient(top, #b4b4b4, #b4b4b4);
background-image: linear-gradient(top, #b4b4b4, #b4b4b4);
background-repeat: repeat-x;
- Content Element
@@ -2451,7 +2435,6 @@
button[id=“add”]:active {
background-color: #1aa200 !important;
-/Button Ende #######################################################/
- EGroupware: Stylite Pixelegg template
@@ -3379,10 +3362,6 @@
td.lettersearch {
background-image: none;
-/*.nextmatch_header table {
border: none !important;
width: 99% !important;
@@ -5160,21 +5139,6 @@
@package pixelegg
@version $Id$
-/ disabled for now in pixelegg.less, until we use svg outside filemanager thumbnails
-//SVG Filter / not for Logo
-#egw_fw_sidebar img[src$=“svg”]{
-#egw_fw_main img[src$=“svg”],
-#egw_fw_footer img[src$=“svg”]{
//.gradient_vertical (@egw_color_2_a, @egw_color_2_a);
.gradient_vertical (fade(@gray_100,50%), fade(@gray_100,50%));
— trunk/pixelegg/css/pixelegg.css (original)
+++ trunk/pixelegg/css/pixelegg.css Fri Apr 15 14:42:38 2016
@@ -1473,26 +1473,6 @@
border-left: none;
- font styling
@@ -2055,12 +2035,13 @@
padding-left: 30px;
height: 24px;
@@ -2074,6 +2055,9 @@
- Content Element
@@ -2440,7 +2424,6 @@
@@ -3368,10 +3351,6 @@
td.lettersearch {
@@ -5149,21 +5128,6 @@
@package pixelegg
@version $Id$
— trunk/pixelegg/less/layout_buttons.less (original)
+++ trunk/pixelegg/less/layout_buttons.less Fri Apr 15 14:42:38 2016
@@ -95,13 +95,15 @@
button.et2_button_with_image{
.Complete_Button_text_icon_before;
- Content Element
- Button löschen / delete / => color-negative-action // red
— trunk/pixelegg/less/svg.css (original)
+++ trunk/pixelegg/less/svg.css Fri Apr 15 14:42:38 2016
@@ -16,28 +16,3 @@
/stroke: @gray_50;/
/fill: @gray_0;/
-svg#etemplate_navbar {
-svg#infolog_navbar {
-svg#admin_navbar {
-.egw_fw_ui_tabs_header > svg * {
- fill: @egw_color_2_a !important;
- stroke: @gray_0 !important;
-svg#sambaadmin_navbar {
-svg#mail_navbar {
— trunk/pixelegg/mobile/fw_mobile.css (original)
+++ trunk/pixelegg/mobile/fw_mobile.css Fri Apr 15 14:42:38 2016
@@ -1057,7 +1057,7 @@
@version $Id: jquery-ui.less 55245 2016-03-04 09:21:40Z ralfbecker $
@version $Id: jquery-ui.less 55742 2016-04-13 18:44:45Z nathangray $
#uical_select_resource {
background-color: #ffdd73;
@@ -1494,26 +1494,6 @@
border-left: none;
@version $Id: traditional.less 50764 2014-03-17 14:10:27Z pixelegg $
- font styling
@@ -2077,12 +2057,13 @@
padding-left: 30px;
height: 24px;
@@ -2096,6 +2077,9 @@
- Content Element
@@ -2462,7 +2446,6 @@
@@ -3390,10 +3373,6 @@
td.lettersearch {
@@ -5171,21 +5150,6 @@
@package pixelegg
@version $Id: layout_table.less 3089 2014-06-11 14:02:57Z pixelegg $
eGroupWare-cvs mailing list
