Author: nathangray
New Revision: 55771
URL: http://svn.stylite.de/viewvc/egroupware?rev=55771&view=rev
Fix error causing relative columns to have 0 width under some resize conditions
trunk/egroupware/api/js/etemplate/et2_dataview_model_columns.js
— trunk/egroupware/api/js/etemplate/et2_dataview_model_columns.js (original)
+++ trunk/egroupware/api/js/etemplate/et2_dataview_model_columns.js Tue Apr 19 00:08:41 2016
@@ -404,7 +404,7 @@
for(columnIndex = 0; columnIndex < this.columns.length; columnIndex++)
if(this.columns[columnIndex].visibility === ET2_COL_VISIBILITY_INVISIBLE ||
eGroupWare-cvs mailing list
