Author: nathangray
New Revision: 55776
URL: http://svn.stylite.de/viewvc/egroupware?rev=55776&view=rev
Apply show_weekends to planner view
trunk/calendar/js/et2_widget_planner.js
trunk/calendar/js/et2_widget_planner_row.js
trunk/calendar/templates/default/app.css
— trunk/calendar/js/et2_widget_planner.js (original)
+++ trunk/calendar/js/et2_widget_planner.js Tue Apr 19 22:27:09 2016
@@ -39,6 +39,12 @@
type: “string”,
default: ‘’,
description: ‘A filter that is used to select events. It is passed along when events are queried.’
show_weekend: {
type: "boolean",
default: egw.preference('days_in_weekview','calendar') != 5,
description: "Display weekends. The date range should still include them for proper scrolling, but they just won't be shown."
value: {
type: "any",
@@ -1012,6 +1018,7 @@
var t = new Date(start.valueOf() + start.getTimezoneOffset() * 60 * 1000);
for(var left = 0,i = 0; i < days; t.setDate(t.getDate()+1),left += day_width,++i)
@@ -1034,7 +1041,7 @@
state = new Date(t.valueOf() - start.getTimezoneOffset() * 60 * 1000).toJSON();
content += '<div class="calendar_plannerDayScale et2_clickable et2_link '+ day_class+
@@ -1076,6 +1083,7 @@
for(var left = 0,i = 0; i < hours; left += cell_width,i += decr)
if(!this.options.show_weekend && [0,6].indexOf(t.getDay()) !== -1 ) continue;
var title = date(egw.preference('timeformat','calendar') == 12 ? 'ha' : 'H',t);
content += '<div class="calendar_plannerHourScale et2_link" data-date="' + t.toJSON() +'" style="left: '+left+'%; width: '+(cell_width)+'%;">'+title+"</div>";
@@ -1639,6 +1647,24 @@
- Turn on or off the visibility of weekends
@param {boolean} weekends
- set_show_weekend: function(weekends)
weekends = weekends ? true : false;
if(this.options.show_weekend !== weekends)
this.options.show_weekend = weekends;
if(this.isAttached())
this.invalidate();
- Call change handler, if set
@param {type} event
— trunk/calendar/js/et2_widget_planner_row.js (original)
+++ trunk/calendar/js/et2_widget_planner_row.js Tue Apr 19 22:27:09 2016
@@ -104,14 +104,14 @@
this.rows.remove(’.calendar_eventRowsMarkedDay,.calendar_eventRowsFiller’).nextAll().remove();
var days = 31;
@@ -125,7 +125,7 @@
// add a filler for non existing days in that month
this.rows.after(’<div class=“calendar_eventRowsFiller”’+
@@ -406,8 +406,29 @@
if(t <= start) return 0; // We are left of our scale
if(t >= end) return 100; // We are right of our scale
// Remove space for weekends, if hidden
var weekend_count = 0;
var weekend_before = 0;
if(this._parent.options.group_by !== 'month' && this._parent && !this._parent.options.show_weekend)
var counter_date = new Date(start);
do
if([0,6].indexOf(counter_date.getUTCDay()) !== -1)
weekend_count++;
if(counter_date < t) weekend_before++;
counter_date.setUTCDate(counter_date.getUTCDate() + 1);
} while(counter_date < end)
// Put it in ms
weekend_before *= 24 * 3600 * 1000;
weekend_count *= 24 * 3600 * 1000;
// Basic scaling, doesn't consider working times
— trunk/calendar/templates/default/app.css (original)
+++ trunk/calendar/templates/default/app.css Tue Apr 19 22:27:09 2016
@@ -1045,6 +1045,9 @@
width: 100%;
height: 20px;
line-height: 20px;
- display: flex;
- flex-wrap: nowrap;
- align-content: stretch;
.calendar_plannerDayScale,.calendar_plannerMonthScale,.calendar_plannerWeekScale,.calendar_plannerHourScale,.calendar_plannerDayOfMonthScale {
position: absolute;
@@ -1059,6 +1062,10 @@
- left:
- width:
+.calendar_plannerDayScale,.calendar_plannerWeekScale,.calendar_plannerHourScale {
- position: static;
- flex: 1 1 14%;
font-size: 90%;
— trunk/calendar/templates/pixelegg/app.css (original)
+++ trunk/calendar/templates/pixelegg/app.css Tue Apr 19 22:27:09 2016
@@ -11,7 +11,7 @@
@package calendar
@version $Id$
-/ $Id: app.css 55765 2016-04-18 19:03:35Z nathangray $ /
+/ $Id: app.css 55773 2016-04-19 17:31:24Z nathangray $ /
/Media print classes/
@media print {
#calendar-view.et2_container,
@@ -128,7 +128,7 @@
padding: 2px;
background-color: white;
-/ Loader /
+/ Loader - hide sizing behind overlay*/
#egw-loadin-prompt_calendar::before {
opacity: 1;
background-color: #e6e6e6;
@@ -1015,6 +1015,9 @@
width: 100%;
height: 20px;
line-height: 20px;
- display: flex;
@@ -1034,6 +1037,12 @@
- width:
+.calendar_plannerWeekScale,
+.calendar_plannerHourScale {
- position: static;
- flex: 1 1 14%;
font-size: 90%;
@@ -1111,6 +1120,7 @@
.calendar_eventRowsFiller {
position: absolute;
top: 0px;
- right: 0px;
height: 93%;
border: 1px dashed gray;
eGroupWare-cvs mailing list
