Author: nathangray
New Revision: 55786
URL: http://svn.stylite.de/viewvc/egroupware?rev=55786&view=rev
Use event sorting from daycol to keep event order within a row more consistent
trunk/calendar/js/et2_widget_planner_row.js
— trunk/calendar/js/et2_widget_planner_row.js (original)
+++ trunk/calendar/js/et2_widget_planner_row.js Wed Apr 20 17:40:09 2016
@@ -309,6 +309,20 @@
this._children.sort(function(a,b) {
var start = new Date(a.options.value.start) - new Date(b.options.value.start);
var end = new Date(a.options.value.end) - new Date(b.options.value.end);
// Whole day events sorted by ID, normal events by start / end time
if(a.options.value.whole_day && b.options.value.whole_day)
// Longer duration comes first so we have nicer bars across the top
var duration =
(new Date(b.options.value.end) - new Date(b.options.value.start)) -
(new Date(a.options.value.end) - new Date(a.options.value.start));
return duration ? duration : (a.options.value.app_id - b.options.value.app_id);
else if (a.options.value.whole_day || b.options.value.whole_day)
return a.options.value.whole_day ? -1 : 1;
return start ? start : end;
eGroupWare-cvs mailing list
