Author: hnategh
New Revision: 55787
URL: http://svn.stylite.de/viewvc/egroupware?rev=55787&view=rev
Fix delete button in calendar edit does not work for mobile theme
trunk/calendar/templates/mobile/edit.xet
— trunk/calendar/templates/mobile/edit.xet (original)
+++ trunk/calendar/templates/mobile/edit.xet Wed Apr 20 18:00:04 2016
@@ -227,7 +227,7 @@
<button statustext="delete this entry" id="button[delete]" onclick="if($cont[info_anz_subs]) return $cont[info_anz_subs]; et2_dialog.confirm(widget,'Delete this entry','Delete');" image="delete" background_image="1" span="all"/>
<button statustext="delete this entry" id="button[delete]" onclick="et2_dialog.confirm(widget,'Delete this entry','Delete');" image="delete" background_image="1" span="all"/>
<buttononly statustext="Find free timeslots where the selected participants are availible for the given timespan" id="freetime" label="Freetime" onclick="app.calendar.freetime_search" image="add" background_image="1"/>
<checkbox label="notification" id="no_notifications"/>
<textbox type="hidden" id="delete_exceptions"/>
eGroupWare-cvs mailing list
