Author: ralfbecker
New Revision: 55801
URL: http://svn.stylite.de/viewvc/egroupware?rev=55801&view=rev
move admin >> Site config to new et2 based site-config
Added:
trunk/admin/templates/default/site-config.xet
- copied, changed from r55790, trunk/admin/templates/default/config.xet
Removed:
trunk/admin/templates/default/config.tpl
trunk/admin/inc/class.admin_config.inc.php
trunk/admin/inc/class.admin_hooks.inc.php
trunk/admin/inc/class.uiconfig.inc.php
trunk/admin/lang/ (props changed)
trunk/admin/setup/setup.inc.php
trunk/admin/templates/default/app.css
trunk/admin/templates/pixelegg/app.css
trunk/egroupware/doc/config2xet.php
— trunk/admin/inc/class.admin_config.inc.php (original)
+++ trunk/admin/inc/class.admin_config.inc.php Thu Apr 21 18:39:59 2016
@@ -35,7 +35,7 @@
if ($GLOBALS[‘egw’]->acl->check(‘site_config_acce’,1,‘admin’))
@@ -56,7 +56,7 @@
case ‘phpgwapi’:
case ‘’:
/* This keeps the admin from getting into what is a setup-only config */
@@ -68,7 +68,7 @@
$c->read_repository();
if ($_content[‘cancel’] || ($_content[‘save’] || $_content[‘apply’]) && $GLOBALS[‘egw’]->acl->check(‘site_config_acce’,2,‘admin’))
@@ -118,8 +118,8 @@
if(!$errors && !$_content['apply'])
egw_framework::message(lang('Configuration saved.'), 'success');
egw::redirect_link('/index.php', array(
Api\Framework::message(lang('Configuration saved.'), 'success');
Api\Framework::redirect_link('/index.php', array(
'menuaction' => 'admin.admin_ui.index',
'ajax' => 'true'
), 'admin');
@@ -128,21 +128,34 @@
if($errors)
$sel_options = $readonlys = array();
$config = $c->read_repository();
// call "config" hook, allowing apps to overwrite config, eg. set default values,
// or return options in "sel_options" keys
$config['location'] = 'config';
$ret = Api\Hooks::single($config, $appname);
if (is_array($ret))
if (isset($ret['sel_options'])) $sel_options = $ret['sel_options'];
$config = array_merge($config, $ret);
$tmpl = new Api\Etemplate($appname.'.config');
$path = (parse_url($tmpl->rel_path, PHP_URL_SCHEME) !== 'vfs' ? EGW_SERVER_ROOT : '').$tmpl->rel_path;
$content = array(
'template' => $appname.'.config',
'newsettings' => array(),
// for security reasons we do not send all config to client-side, but only ones mentioned in templates
$matches = null;
@@ -152,6 +165,14 @@
$content[‘newsettings’][$name] = $config[$name];
$tmpl->exec('admin.admin_config.index', $content, array(), array(), array('appname' => $appname));
// make everything readonly and remove save/apply button, if user has not rights to store config
if ($GLOBALS['egw']->acl->check('site_config_acce',2,'admin'))
$readonlys[__ALL__] = true;
$readonlys['cancel'] = false;
$tmpl->read('admin.site-config');
$tmpl->exec('admin.admin_config.index', $content, $sel_options, $readonlys, array('appname' => $appname));
— trunk/admin/inc/class.admin_hooks.inc.php (original)
+++ trunk/admin/inc/class.admin_hooks.inc.php Thu Apr 21 18:39:59 2016
@@ -57,7 +57,7 @@
if (! $GLOBALS['egw']->acl->check('site_config_acce',1,'admin'))
$file['Site Configuration'] = egw::link('/index.php','menuaction=admin.admin_config.index&appname=admin&ajax=true');
if (! $GLOBALS['egw']->acl->check('account_access',1,'admin'))
@@ -251,4 +251,20 @@
return $actions;
— trunk/admin/inc/class.uiconfig.inc.php (original)
+++ trunk/admin/inc/class.uiconfig.inc.php Thu Apr 21 18:39:59 2016
@@ -20,6 +20,12 @@
function index($params=null)
// if we have a xet file, run new et2 config
if (file_exists(EGW_SERVER_ROOT.'/'.$_GET['appname'].'/templates/default/config.xet'))
$new_config = new admin_config();
return $new_config->index();
// allowing inline js
egw_framework::csp_script_src_attrs('unsafe-inline');
Propchange: trunk/admin/lang/
— svn:ignore (original)
+++ svn:ignore Thu Apr 21 18:39:59 2016
@@ -1,2 +1,3 @@
egw_de.lang.old
egw_en.lang.old
+.!5805!egw_tr.lang
— trunk/admin/setup/setup.inc.php (original)
+++ trunk/admin/setup/setup.inc.php Thu Apr 21 18:39:59 2016
@@ -38,6 +38,7 @@
$setup_info[‘admin’][‘hooks’][‘admin’] = ‘admin_hooks::all_hooks’;
$setup_info[‘admin’][‘hooks’][‘sidebox_menu’] = ‘admin_hooks::all_hooks’;
$setup_info[‘admin’][‘hooks’][‘edit_user’] = ‘admin_hooks::edit_user’;
+$setup_info[‘admin’][‘hooks’][‘config’] = ‘admin_hooks::config’;
// add account tab to addressbook.edit
$setup_info[‘admin’][‘hooks’][‘addressbook_edit’] = ‘admin.admin_account.addressbook_edit’;
— trunk/admin/templates/default/app.css (original)
+++ trunk/admin/templates/default/app.css Thu Apr 21 18:39:59 2016
@@ -157,7 +157,14 @@
- new et2 site configuration
-table.admin-config td.subHeader span {
+#admin-site-config > div > span.subHeader {
- border-bottom: 3px solid #696969;
- padding-left: 3px;
- padding-bottom: 3px;
- display: block;
- margin-bottom: 5px;
+#admin-site-config span.subHeader {
font-weight: bold;
font-size: 110%;
— trunk/admin/templates/default/config.xet (original)
+++ trunk/admin/templates/default/config.xet Thu Apr 21 18:39:59 2016
@@ -9,9 +9,6 @@
<row>
<description value="Site configuration" span="all" class="subHeader"/>
</row>
<row>
<description value="Should the login page include a language selectbox (useful for demo-sites) ?" label="%s:"/>
<select id="newsettings[login_show_language_selection]">
@@ -94,7 +91,7 @@
@@ -103,7 +100,7 @@
Document root (default)
@@ -228,7 +225,7 @@
@@ -254,10 +251,5 @@
<hbox class="dialogFooterToolbar">
<button id="save" label="Save"/>
<button id="apply" label="Apply"/>
<button id="cancel" label="Cancel"/>
</hbox>
+++ trunk/admin/templates/default/site-config.xet Thu Apr 21 18:39:59 2016
@@ -2,258 +2,9 @@
- No
- Yes
- {Firstname}.{Lastname}@domain.com
- {Firstname}{Lastname}@domain.com
- {Firstname}_{Lastname}@domain.com
- {Initial}{Lastname}@domain.com
- {Initial}.{Lastname}@domain.com
- {Lastname}.{Firstname}@domain.com
- {Lastname}{Firstname}@domain.com
- {Lastname}_{Firstname}@domain.com
- {Lastname}@domain.com
- {Firstname}@domain.com
- {Username}@domain.com
- No
- Yes
- {No} - {more secure}
- Yes
- Yes, but no SCAYT
- {Yes, use browser based spell checking engine} - {more secure}
- Yes, use WebSpellChecker
- Enable
- Hide sidebox video tutorials
- Do not offer introduction video
- Disable all
- Document root (default)
- eGroupWare directory
- {Yes} - {more secure}
- No
- No
- No
- Yes
- None
- 6
- 7
- 8
- 10
- 12
- 14
- 16
- None
- 2
- 3
- 4
- No
- Yes
- Yes
- {No} - {Default}
- Yes
- Debug
— trunk/admin/templates/pixelegg/app.css (original)
+++ trunk/admin/templates/pixelegg/app.css Thu Apr 21 18:39:59 2016
@@ -18,7 +18,7 @@
@version $Id: app.css 55532 2016-03-28 18:51:38Z ralfbecker $
@version $Id: app.css 55790 2016-04-20 18:52:55Z ralfbecker $
.admin_tree table,
.admin_tree tr,
@@ -163,7 +163,14 @@
- display: block;
font-weight: bold;
font-size: 110%;
— trunk/egroupware/doc/config2xet.php (original)
+++ trunk/egroupware/doc/config2xet.php Thu Apr 21 18:39:59 2016
@@ -55,9 +55,6 @@
foreach($trs[2] as $n => $tr)
@@ -164,11 +161,6 @@
echo
</hbox>
eGroupWare-cvs mailing list
