Author: ralfbecker
New Revision: 55813
URL: http://svn.stylite.de/viewvc/egroupware?rev=55813&view=rev
use new et2 config
Added:
trunk/calendar/templates/default/config.xet (with props)
Removed:
trunk/calendar/templates/default/config.tpl
trunk/admin/templates/default/site-config.xet
trunk/calendar/inc/class.calendar_hooks.inc.php
trunk/calendar/inc/class.calendar_ui.inc.php
— trunk/admin/templates/default/site-config.xet (original)
+++ trunk/admin/templates/default/site-config.xet Sun Apr 24 15:41:36 2016
@@ -4,7 +4,7 @@
— trunk/calendar/inc/class.calendar_hooks.inc.php (original)
+++ trunk/calendar/inc/class.calendar_hooks.inc.php Sun Apr 24 15:41:36 2016
@@ -5,7 +5,7 @@
'Site Configuration' => egw::link('/index.php','menuaction=admin.admin_config.index&appname=calendar&ajax=true'),
'Custom fields' => egw::link('/index.php','menuaction=admin.customfields.index&appname=calendar'),
'Calendar Holiday Management' => egw::link('/index.php','menuaction=calendar.uiholiday.admin'),
'Global Categories' => egw::link('/index.php','menuaction=admin.admin_categories.index&appname=calendar'),
— trunk/calendar/inc/class.calendar_ui.inc.php (original)
+++ trunk/calendar/inc/class.calendar_ui.inc.php Sun Apr 24 15:41:36 2016
@@ -370,7 +370,7 @@
$this->view_menuaction = $this->view == ‘listview’ ? ‘calendar.calendar_uilist.listview’ : ‘calendar.calendar_uiviews.index’;
if ($this->debug > 0 || $this->debug == 'manage_states') $this->bo->debug_message('uical::manage_states(%1) session was %2, states now %3',True,$set_states,$states_session,$states);
if ($this->debug > 0 || $this->debug == 'manage_states') $this->bo->debug_message('uical::manage_states(%1), states now %3',True,$set_states,$states);
// save the states in the session only when we are in calendar
if ($GLOBALS['egw_info']['flags']['currentapp']=='calendar')
@@ -480,7 +480,6 @@
function sidebox_menu()
@@ -520,7 +519,7 @@
if ($GLOBALS[‘egw_info’][‘user’][‘apps’][‘admin’])
$file = Array(
'Configuration'=>egw::link('/index.php','menuaction=admin.admin_config.index&appname=calendar&ajax=true'),
'Custom Fields'=>egw::link('/index.php','menuaction=admin.customfields.index&appname=calendar'),
'Holiday Management'=>egw::link('/index.php','menuaction=calendar.uiholiday.admin'),
'Global Categories' =>egw::link('/index.php','menuaction=admin.admin_categories.index&appname=calendar'),
@@ -688,6 +687,7 @@
$event[‘non_blocking’] = (bool)$event[‘non_blocking’];
— trunk/calendar/templates/default/config.xet (added)
+++ trunk/calendar/templates/default/config.xet Sun Apr 24 15:41:36 2016
@@ -1,0 +1,118 @@
+<?xml version="1.0" encoding="UTF-8"?>
<grid width="100%" class="admin-config egwGridView_grid">
<columns>
<column width="60%"/>
<column/>
</columns>
<rows>
<row>
<description value="Do you wish to autoload calendar holidays files dynamically?"/>
<select id="newsettings[auto_load_holidays]">
<option value="">No</option>
<option value="True">Yes</option>
</select>
</row>
<row>
<description value="Location to autoload from" label="%s:"/>
<select id="newsettings[holidays_url_path]">
<option value="localhost">localhost</option>
<option value="http://www.egroupware.org/cal">www.egroupware.org</option>
</select>
</row>
<row>
<description value="setting lock time calender" label="%s:"/>
<textbox id="newsettings[Lock_Time_Calender]" size="40"/>
</row>
<row>
<description value="Deny Ressources reservation for private events" label="%s:"/>
<select id="newsettings[no_ressources_private]">
<option value="yes">Yes</option>
</select>
</row>
<row>
<description value="Require an ACL grant to invite other users and groups" label="%s:"/>
<select id="newsettings[require_acl_invite]">
<option value="">{No}: {Every user can invite other users and groups}</option>
<option value="groups">Groups: other users can allways be invited, only groups require an invite grant</option>
<option value="all">Users + groups: inviting both allways requires an invite grant</option>
</select>
</row>
<row>
<description value="Allow users to prevent change notifications ('Do not notify')" label="%s:"/>
<select id="newsettings[calendar_allow_no_notification]">
</select>
</row>
<row>
<description value="Use range-views to optimise calendar queries?"/>
<select id="newsettings[no_timerange_views]">
<option value="">Yes</option>
<option value="true">No</option>
</select>
</row>
<row>
<description value="Security" span="all" class="subHeader"/>
</row>
<row>
<vbox>
<description value="How many appointments should non-admins be able to export"/>
<description value="(empty = use global limit, no = no export at all)"/>
</vbox>
<textbox id="newsettings[calendar_export_limit]" size="5"/>
</row>
<row>
<description value="History logging" span="all" class="subHeader"/>
</row>
<row>
<description value="Prevent deleting of entries"/>
<select id="newsettings[calendar_delete_history]">
<option value="history">Yes, only admins can purge deleted items</option>
<option value="userpurge">Yes, users can purge their deleted items</option>
</select>
</row>
<row>
<description value="Automatically purge old events after"/>
<select id="newsettings[calendar_purge_old]">
<option value="0ff">No automatic purging</option>
<option value=".5">0.5 {years}</option>
<option value="1">1 {year}</option>
<option value="2">2 {years}</option>
<option value="3">3 {years}</option>
<option value="4">4 {years}</option>
<option value="5">5 {years}</option>
<option value="10">10 {years}</option>
</select>
</row>
<row>
<description value="Birthdays" span="all" class="subHeader"/>
</row>
<row>
<description value="Show birthdays from addressbook" label="%s:"/>
<select id="newsettings[hide_birthdays]">
<option value="dateonly">Show only the date, not the year</option>
<option value="yes">No</option>
</select>
</row>
<row>
<description value="Calendar recurrence horizont in days (default 1000)" label="%s:"/>
<textbox id="newsettings[calendar_horizont]" size="5"/>
</row>
<row>
<description value="Create links for participants from addressbook" label="%s:"/>
<select id="newsettings[link_contacts]">
</select>
</row>
</rows>
</grid>
Propchange: trunk/calendar/templates/default/config.xet
svn:eol-style = native
svn:keywords = Author Date Id Rev URL
svn:mime-type = text/xml
eGroupWare-cvs mailing list
