Author: ralfbecker
New Revision: 55824
URL: http://svn.stylite.de/viewvc/egroupware?rev=55824&view=rev
using new et2 site config
Added:
trunk/phpbrain/templates/default/config.xet (with props)
Removed:
trunk/phpbrain/templates/default/config.tpl
trunk/phpbrain/inc/hook_admin.inc.php
trunk/phpbrain/inc/hook_sidebox_menu.inc.php
— trunk/phpbrain/inc/hook_admin.inc.php (original)
+++ trunk/phpbrain/inc/hook_admin.inc.php Mon Apr 25 12:53:23 2016
@@ -1,24 +1,23 @@
<?php
- * eGroupWare - KnowledgeBase *
- * http://www.egroupware.org *
- * Written by Dave Hall [dave.hall at mbox.com.au] *
- * Started off as a port of phpBrain - http://vrotvrot.com/phpBrain/ *
- * but quickly became a full rewrite *
- * This program is free software; you can redistribute it and/or modify it *
- * under the terms of the GNU General Public License as published by the *
- * Free Software Foundation; either version 2 of the License, or (at your *
- * option) any later version. *
+* eGroupWare - KnowledgeBase *
+* http://www.egroupware.org *
+* Written by Dave Hall [dave.hall at mbox.com.au] *
+* Started off as a port of phpBrain - http://vrotvrot.com/phpBrain/ *
+* but quickly became a full rewrite *
+* This program is free software; you can redistribute it and/or modify it *
+* under the terms of the GNU General Public License as published by the *
+* Free Software Foundation; either version 2 of the License, or (at your *
+* option) any later version. *
- $file = array
- 'Site Configuration' => $GLOBALS['egw']->link('/index.php','menuaction=admin.uiconfig.index&appname=' . $appname),
- 'Global Categories' => $GLOBALS['egw']->link('/index.php','menuaction=admin.admin_categories.index&appname=phpbrain')
- display_section($appname,$file);
- $file = array
'Site Configuration' => egw::link('/index.php','menuaction=admin.admin_config.index&appname=' . $appname.'&ajax=true'),
'Global Categories' => egw::link('/index.php','menuaction=admin.admin_categories.index&appname=phpbrain')
— trunk/phpbrain/inc/hook_sidebox_menu.inc.php (original)
+++ trunk/phpbrain/inc/hook_sidebox_menu.inc.php Mon Apr 25 12:53:23 2016
@@ -1,15 +1,15 @@
<?php
- * eGroupWare - Knowledge Base *
+* eGroupWare - Knowledge Base *
- /* $Id$ */
+/* $Id$ */
$menu_title = $GLOBALS['egw_info']['apps'][$appname]['title'] . ' '. lang('Menu');
$file=Array(
@@ -25,8 +25,8 @@
$menu_title = 'Administration';
$file = Array(
- 'Configuration' => $GLOBALS['egw']->link('/index.php','menuaction=admin.uiconfig.index&appname=phpbrain'),
+ 'Site Configuration' => egw::link('/index.php','menuaction=admin.admin_config.index&appname=' . $appname.'&ajax=true'),
+ 'Global Categories' => egw::link('/index.php','menuaction=admin.admin_categories.index&appname=phpbrain')
display_sidebox($appname,$menu_title,$file);
Added: trunk/phpbrain/templates/default/config.xet
URL: http://svn.stylite.de/viewvc/egroupware/trunk/phpbrain/templates/default/config.xet?rev=55824&view=auto
--- trunk/phpbrain/templates/default/config.xet (added)
+++ trunk/phpbrain/templates/default/config.xet Mon Apr 25 12:53:23 2016
@@ -1,0 +1,54 @@
+<?xml version="1.0" encoding="UTF-8"?>
<grid width="100%" class="admin-config egwGridView_grid">
<columns>
<column width="60%"/>
<column/>
</columns>
<rows>
<row>
<description value="Publish articles automatically?"/>
<select id="newsettings[publish_articles]">
<option value="True">Yes</option>
<option value="False">Have to be approved first</option>
</select>
</row>
<row>
<description value="Allow the publishing of articles by the author? (effective only if the approval of articles is required)"/>
<select id="newsettings[publish_own_articles]">
<option value="False">No</option>
</select>
</row>
<row>
<description value="Publish comments automatically?"/>
<select id="newsettings[publish_comments]">
</select>
</row>
<row>
<description value="Publish questions automatically?"/>
<select id="newsettings[publish_questions]">
</select>
</row>
<row>
<description value="Should the article view make an automatic table of contents?"/>
<select id="newsettings[show_toc]">
</select>
</row>
<row>
<description value="Name of the backlink to the index:"/>
<textbox id="newsettings[backlinkText]" size="40"/>
</row>
</rows>
</grid>
Propchange: trunk/phpbrain/templates/default/config.xet
svn:eol-style = native
svn:keywords = Author Date Id Rev URL
svn:mime-type = text/xml
eGroupWare-cvs mailing list
