Author: nathangray
New Revision: 55840
URL: http://svn.stylite.de/viewvc/egroupware?rev=55840&view=rev
Hide granularity change so you don’t have to see it
trunk/calendar/js/app.js
trunk/calendar/js/et2_widget_timegrid.js
trunk/calendar/js/et2_widget_view.js
trunk/calendar/templates/default/app.css
— trunk/calendar/js/app.js (original)
+++ trunk/calendar/js/app.js Tue Apr 26 00:09:57 2016
@@ -2075,6 +2075,7 @@
if(widget.set_granularity)
— trunk/calendar/js/et2_widget_timegrid.js (original)
+++ trunk/calendar/js/et2_widget_timegrid.js Tue Apr 26 00:09:57 2016
@@ -562,7 +562,7 @@
this.widget.change();
// Hide loader
window.setTimeout(jQuery.proxy(function() {this.loader.hide();},this.widget),200);
},{widget:this,"trigger":trigger}),ET2_GRID_INVALIDATE_TIMEOUT);
@@ -1388,7 +1388,7 @@
// None of the above changed anything, hide the loader
if(!this.update_timer)
— trunk/calendar/js/et2_widget_view.js (original)
+++ trunk/calendar/js/et2_widget_view.js Tue Apr 26 00:09:57 2016
@@ -294,7 +294,7 @@
— trunk/calendar/templates/default/app.css (original)
+++ trunk/calendar/templates/default/app.css Tue Apr 26 00:09:57 2016
@@ -275,6 +275,10 @@
right: 0px;
position: absolute;
+.calendar_calTimeGrid .loading::before ,.calendar_plannerWidget .loading::before {
- opacity: 1;
- background-color: #E6E6E6;
/* Timegrid that has hit a minimum size */
.calendar_calTimeGridFixed .calendar_calTimeGridScroll {
overflow: hidden;
— trunk/calendar/templates/pixelegg/app.css (original)
+++ trunk/calendar/templates/pixelegg/app.css Tue Apr 26 00:09:57 2016
@@ -11,7 +11,7 @@
@package calendar
@version $Id$
-/ $Id: app.css 55784 2016-04-20 15:07:01Z nathangray $ /
+/ $Id: app.css 55805 2016-04-21 20:30:48Z nathangray $ */
/Media print classes/
@media print {
#calendar-view.et2_container,
@@ -280,6 +280,11 @@
right: 0px;
position: absolute;
+.calendar_calTimeGrid .loading::before,
+.calendar_plannerWidget .loading::before {
- opacity: 1;
overflow: hidden;
eGroupWare-cvs mailing list
