Author: hnategh
New Revision: 55844
URL: http://svn.stylite.de/viewvc/egroupware?rev=55844&view=rev
Change owner tab order for calendar edit dialog
trunk/calendar/templates/default/edit.xet
trunk/calendar/templates/mobile/edit.xet
— trunk/calendar/templates/default/edit.xet (original)
+++ trunk/calendar/templates/default/edit.xet Tue Apr 26 14:33:25 2016
@@ -251,11 +251,13 @@
<row disabled="!@owner" class="dialogOperators">
<description value="Owner"/>
<menulist>
<menupopup type="select-account" id="owner" readonly="true"/>
</menulist>
<row disabled="!@id" class="dialogOperators">
<hbox span="2">
<date-time label="created" id="created" no_lang="1" readonly="true"/>
<menulist>
<menupopup label = "by" type="select-account" id="owner" readonly="true"/>
</menulist>
</hbox>
<hbox align="right">
<date-time label="Updated" id="modified" no_lang="1" readonly="true"/>
<menulist>
— trunk/calendar/templates/mobile/edit.xet (original)
+++ trunk/calendar/templates/mobile/edit.xet Tue Apr 26 14:33:25 2016
@@ -197,21 +197,23 @@
<row disabled="!@id">
<description value="Created"/>
<hbox>
<menulist>
</menulist>
<date-time id="created" no_lang="1" readonly="true"/>
</hbox>
</row>
<row disabled="!@modified">
<description value="Updated"/>
<date-time id="modified" no_lang="1" readonly="true"/>
</row>
<row disabled="!@modifier">
<description value="by"/>
<menulist>
<menupopup type="select-account" class="et2_nowrap" id="modifier" readonly="true"/>
</menulist>
<hbox>
<menulist>
</menulist>
</hbox>
</row>
</rows>
</grid>
@@ -225,11 +227,10 @@
<button statustext="Saves this entry" id="button[save]" image="save" background_image="1"/>
<button statustext="Apply the changes" id="button[apply]" image="apply" background_image="1"/>
<button statustext="delete this entry" id="button[delete]" onclick="et2_dialog.confirm(widget,'Delete this entry','Delete');" image="delete" background_image="1" span="all"/>
<buttononly statustext="Find free timeslots where the selected participants are availible for the given timespan" id="freetime" label="Freetime" onclick="app.calendar.freetime_search" image="add" background_image="1"/>
<checkbox label="notification" id="no_notifications"/>
eGroupWare-cvs mailing list
