Author: hnategh
New Revision: 55846
URL: http://svn.stylite.de/viewvc/egroupware?rev=55846&view=rev
Addressbook edit dialog:
- Fix category id in mobile template
- Implement categories in mobile view template
- Remove not used buttons
trunk/addressbook/templates/default/edit.xet
trunk/addressbook/templates/mobile/edit.xet
trunk/addressbook/templates/mobile/view.xet
— trunk/addressbook/templates/default/edit.xet (original)
+++ trunk/addressbook/templates/default/edit.xet Tue Apr 26 15:31:52 2016
@@ -174,7 +174,7 @@
@@ -449,9 +449,6 @@
<button label="Edit" id="button[edit]" class="button_edit" onclick="window.open(egw::link('/index.php','menuaction=addressbook.addressbook_ui.edit&contact_id=$cont[id]'),'_blank','dependent=yes,width=900,height=560,scrollbars=yes,status=yes'); return false;" image="edit" background_image="1"/>
<button label="Copy" id="button[copy]" class="button_copy" onclick="window.open(egw::link('/index.php','menuaction=addressbook.addressbook_ui.edit&contact_id=$cont[id]&makecp=1'),'_blank','dependent=yes,width=900,height=560,scrollbars=yes,status=yes'); return false;" image="copy" background_image="1"/>
<button statustext="download this contact as vCard file" label="vCard" id="button[vcard]" image="vcard" background_image="1"/>
<button accesskey="s" label="Save" id="button[save]" class="button_save" image="save" background_image="1"/>
<button label="Apply" id="button[apply]" class="button_apply" image="apply" background_image="1"/>
<button label="Cancel" id="button[cancel]" class="button_cancel" onclick="if($cont[view] || false) return true; window.close(); return false;" image="cancel" background_image="1"/>
— trunk/addressbook/templates/mobile/edit.xet (original)
+++ trunk/addressbook/templates/mobile/edit.xet Tue Apr 26 15:31:52 2016
@@ -138,7 +138,7 @@
@@ -362,12 +362,7 @@
<button id="button[edit]" class="button_edit" onclick="window.open(egw::link('/index.php','menuaction=addressbook.addressbook_ui.edit&contact_id=$cont[id]'),'_blank','dependent=yes,width=900,height=560,scrollbars=yes,status=yes'); return false;" image="edit" background_image="1"/>
<button id="button[copy]" class="button_copy" onclick="window.open(egw::link('/index.php','menuaction=addressbook.addressbook_ui.edit&contact_id=$cont[id]&makecp=1'),'_blank','dependent=yes,width=900,height=560,scrollbars=yes,status=yes'); return false;" image="copy" background_image="1"/>
<button statustext="download this contact as vCard file" id="button[vcard]" image="vcard" background_image="1"/>
<button accesskey="s" id="button[save]" class="button_save" image="save" background_image="1"/>
<button id="button[apply]" class="button_apply" image="apply" background_image="1"/>
<button id="button[cancel]" class="button_cancel" onclick="if($cont[view] || false) return true; window.close(); return false;" image="cancel" background_image="1"/>
<button id="button[delete]" class="button_delete" onclick="et2_dialog.confirm(widget,'Do you really want to delete this contact?','Delete')" tabindex="25" image="delete" background_image="1"/>
</hbox>
</row>
— trunk/addressbook/templates/mobile/view.xet (original)
+++ trunk/addressbook/templates/mobile/view.xet Tue Apr 26 15:31:52 2016
@@ -173,6 +173,12 @@
eGroupWare-cvs mailing list
