Author: hnategh
New Revision: 55857
URL: http://svn.stylite.de/viewvc/egroupware?rev=55857&view=rev
Mobile theme:
- Implement auto scrollup on INPUT or SELECT elements focus, makes it easier to enter data when mobile keyboard popups up
trunk/jdots/js/fw_mobile.js
— trunk/jdots/js/fw_mobile.js (original)
+++ trunk/jdots/js/fw_mobile.js Tue Apr 26 18:31:07 2016
@@ -188,6 +188,15 @@
//Remove the loading class
egw.loading_prompt(‘popup’, false);
self.$iFrame.css({visibility:‘visible’});
// Auto scrollup when select input or select
jQuery(popupWindow).on('resize', function(){
if(popupWindow.document.activeElement.tagName == "INPUT" || popupWindow.document.activeElement.tagName == "SELECT"){
popupWindow.setTimeout(function(){
popupWindow.document.activeElement.scrollIntoViewIfNeeded(false);
},0);
eGroupWare-cvs mailing list
