Author: ralfbecker
New Revision: 55880
URL: http://svn.stylite.de/viewvc/egroupware?rev=55880&view=rev
fix sql error after clear cache, because db class has again type “mysqli” instead of just “mysql”
branches/14.2/etemplate/inc/class.so_sql.inc.php
— branches/14.2/etemplate/inc/class.so_sql.inc.php (original)
+++ branches/14.2/etemplate/inc/class.so_sql.inc.php Wed Apr 27 12:42:13 2016
@@ -1135,7 +1135,8 @@
public static function fix_group_by_columns($group_by, &$columns, $table_name, $autoinc_id)
$matches = null;
//error_log(__METHOD__."('$group_by', ..., '$table_name', '$autoinc_id') db->Type=".array2string($GLOBALS['egw']->db->Type));
if (substr($GLOBALS['egw']->db->Type, 0, 5) == 'mysql' || !preg_match('/(GROUP BY .*)(HAVING.*|ORDER BY.*)?$/iU', $group_by, $matches))
return $group_by; // nothing to do
eGroupWare-cvs mailing list
