Author: nathangray
New Revision: 55906
URL: http://svn.stylite.de/viewvc/egroupware?rev=55906&view=rev
- Use datasource to default, fixes addressbook entries not ignored
- Do not set element start date if not supported, fixes addressbook entries got a start date
- Update element totals in header for refresh
- Fix Times / Planned / Replanned totals were not updated
trunk/projectmanager/inc/class.datasource.inc.php
trunk/projectmanager/inc/class.projectmanager_elements_bo.inc.php
trunk/projectmanager/inc/class.projectmanager_elements_ui.inc.php
trunk/projectmanager/templates/default/elements.list.xet
— trunk/projectmanager/inc/class.datasource.inc.php (original)
+++ trunk/projectmanager/inc/class.datasource.inc.php Wed Apr 27 23:09:18 2016
@@ -188,7 +188,8 @@
if ($ds)
// setting a not set planned start from a contrains
if ((!$ds['pe_planned_start'] && isset($ds['pe_planned_start']) || $ds['ignore_planned_start']) &&
!is_null($pe_data) && $pe_data['pe_constraints']['start'])
//echo "start-constr."; _debug_array($pe_data['pe_constraints']['start']);
$start = 0;
@@ -213,12 +214,12 @@
// setting the planned start from the real-start
@@ -255,11 +256,11 @@
// setting real or planned start-date, from each other if not set
— trunk/projectmanager/inc/class.projectmanager_elements_bo.inc.php (original)
+++ trunk/projectmanager/inc/class.projectmanager_elements_bo.inc.php Wed Apr 27 23:09:18 2016
@@ -232,9 +232,12 @@
$this->init();
$need_save_anyway = false;
$datasource =& $this->datasource($app);
// check if entry already exists and set basic values if not
if (!$pe_id || ($need_save_anyway = !$this->read(array('pm_id'=>$pm_id,'pe_id'=>$pe_id))))
$this->data = $datasource->read($id);
$this->data['pm_id'] = $pm_id;
$this->data['pe_id'] = $pe_id;
$this->data['pe_overwrite'] = 0; // none set so far
@@ -256,7 +259,6 @@
$this->data_merge($extra_keys);
— trunk/projectmanager/inc/class.projectmanager_elements_ui.inc.php (original)
+++ trunk/projectmanager/inc/class.projectmanager_elements_ui.inc.php Wed Apr 27 23:09:18 2016
@@ -465,7 +465,7 @@
// Check for filter change, need to get totals
$session = egw_cache::getSession('projectmanager', 'projectelements_list');
$get_totals = $query_in['start'] === 0 || ($session && $session['filter'] != $query_in['filter']) || !$session && $query_in['filter'];
$query=$query_in;
unset($query_in['col_filter']['parent_id']);
$GLOBALS['egw']->session->appsession('projectelements_list','projectmanager',$query_in);
@@ -688,6 +688,11 @@
if ($budget_rights || !in_array($field, array(‘pe_planned_budget’, ‘pe_used_budget’)))
$rows[‘total_’ . $field] = $value;
// etemplate requires unique IDs, these ones are in the second times column
if(in_array($field, array('pe_planned_time', 'pe_used_time')))
$rows['total_' . $field . '_2'] = $value;
— trunk/projectmanager/templates/default/elements.list.xet (original)
+++ trunk/projectmanager/templates/default/elements.list.xet Wed Apr 27 23:09:18 2016
@@ -87,9 +87,9 @@
eGroupWare-cvs mailing list
