Author: ralfbecker
New Revision: 55914
URL: http://svn.stylite.de/viewvc/egroupware?rev=55914&view=rev
copy 14.3 changelog to trunk to satisfy update checker
trunk/egroupware/doc/rpm-build/debian.changes
— trunk/egroupware/doc/rpm-build/debian.changes (original)
+++ trunk/egroupware/doc/rpm-build/debian.changes Thu Apr 28 15:04:41 2016
@@ -1,3 +1,17 @@
+egroupware-epl (14.3.20160428) hardy; urgency=low
- CardDAV: fix not working creation of new CardDAV account with OS X 10.11.4 addressbook (it stays empty)
- CardDAV: SoGo and Busycontacts without all name- or organisation components use last value for missing ones
- CalDAV: fix exceptions (EXDATE) was exported with timezone and Zulu-time, causing eM Clinet to fail
- ProjectManager: fix PHP 5.3 problem: PHP Parse error: syntax error, unexpected “[”
- LDAP: fix “Protocol error” on creating new accounts, if “Do you want to manage home directory and login shell attributes?” is set to yes, but fields are left empty
- Admin: clear cache after admin-cli.php commands, so they become active automatically, also backported feedback for “Clear cache and register hooks” from trunk
- Bookmark: Fix bookmark preview image not getting a right size
- Bookmarks: fixed not displayed favicon for new bookmarks
- Wiki/PostgreSQL: fix SQL error while searching
- – Ralf Becker rb@stylite.de Wed, 27 Apr 2016 21:31:22 +0200
egroupware-epl (14.3.20160304) hardy; urgency=low
- All apps: updated included Horde and PEAR packages (now including PEAR itself) to improve php 7.0 compatibility
eGroupWare-cvs mailing list
