Author: ralfbecker
New Revision: 55968
URL: http://svn.stylite.de/viewvc/egroupware?rev=55968&view=rev
using grunt-hub to run default tasks of Gruntfile.js of apps
trunk/egroupware/Gruntfile.js
— trunk/egroupware/Gruntfile.js (original)
+++ trunk/egroupware/Gruntfile.js Mon May 2 12:28:35 2016
@@ -12,10 +12,12 @@
npm init # create package.json and node_modules directory for local installs
npm install grunt --save-dev
npm install grunt-contrib-uglify --save-dev
npm install grunt-newer --save-dev
npm install grunt-contrib-cssmin --save-dev
@@ -380,6 +382,11 @@
hub: {
all: {
src: ['*/Gruntfile.js']
// Load the plugin that provides the “uglify” task.
@@ -391,6 +398,9 @@
// Load the plugin that runs tasks only on modified files
grunt.loadNpmTasks(‘grunt-newer’);
// run Gruntfile.js in apps / sub-directories
grunt.loadNpmTasks(‘grunt-hub’);
// Default task(s).
- grunt.registerTask(‘default’, [‘newer:uglify’, ‘newer:cssmin’]);
- grunt.registerTask(‘default’, [‘newer:uglify’, ‘newer:cssmin’, ‘hub’]);
eGroupWare-cvs mailing list
