Author: nathangray
New Revision: 55996
URL: http://svn.stylite.de/viewvc/egroupware?rev=55996&view=rev
If the total width of the columns is greater than what is available, distribute the shortage across fixed width columns
trunk/egroupware/api/js/etemplate/et2_dataview_model_columns.js
— trunk/egroupware/api/js/etemplate/et2_dataview_model_columns.js (original)
+++ trunk/egroupware/api/js/etemplate/et2_dataview_model_columns.js Tue May 3 22:55:39 2016
@@ -326,6 +326,7 @@
// Calculate how many space is - relatively - not occupied with columns with
// relative or fixed width
var totalRelative = 0;
@@ -351,6 +352,7 @@
else if (col.fixedWidth)
this.totalFixed += col.fixedWidth;
@@ -405,7 +407,8 @@
if(this.columns[columnIndex].visibility === ET2_COL_VISIBILITY_INVISIBLE ||
this.columns[columnIndex].visibility === ET2_COL_VISIBILITY_DISABLED ||
@@ -423,12 +426,14 @@
if(!column)
col.fixedWidth -= Math.round(this.columnWidths[i] / tw * remaining_width);
this.columnWidths[i] = Math.max(0, Math.min(col.fixedWidth,tw));
if(!col.fixedWidth) continue;
var diff = Math.round(remaining_width / fixedCount);
var new_width = this.columnWidths[i] - diff;
this.columnWidths[i] = Math.max(0, Math.min(new_width,tw));
else
eGroupWare-cvs mailing list
