Author: nathangray
New Revision: 56012
URL: http://svn.stylite.de/viewvc/egroupware?rev=56012&view=rev
Properly handle nextmatch columns where the width is not set
trunk/egroupware/api/js/etemplate/et2_dataview_model_columns.js
trunk/egroupware/api/js/etemplate/et2_extension_nextmatch.js
— trunk/egroupware/api/js/etemplate/et2_dataview_model_columns.js (original)
+++ trunk/egroupware/api/js/etemplate/et2_dataview_model_columns.js Wed May 4 17:48:58 2016
@@ -90,12 +90,19 @@
this.initAttributes(_attrs);
- “100” => fixedWidth 100px
- “100px” => fixedWidth 100px
- “50%” => relativeWidth 50%
@param {float|string} _value
set_width: function(_value) {
// Parse the width parameter. Posible values are:
// 1. "100" => fixedWidth 100px
// 2. "100px" => fixedWidth 100px
// 3. "50%" => relativeWidth 50%
// 4. 0.5 => relativeWidth 50%
@@ -408,7 +415,7 @@
if(this.columns[columnIndex].visibility === ET2_COL_VISIBILITY_INVISIBLE ||
this.columns[columnIndex].visibility === ET2_COL_VISIBILITY_DISABLED ||
this.columnWidths[columnIndex] <= 0 ||
— trunk/egroupware/api/js/etemplate/et2_extension_nextmatch.js (original)
+++ trunk/egroupware/api/js/etemplate/et2_extension_nextmatch.js Wed May 4 17:48:58 2016
@@ -1061,6 +1061,12 @@
“visibility”: visibility,
“width”: _colData[x] ? _colData[x].width : 0
if(_colData[x].width === 'auto')
// Column manager does not understand 'auto', which grid widget
// uses if width is not set
columnData[x].width = '100%';
if(_colData[x].minWidth)
columnData[x].minWidth = _colData[x].minWidth;
eGroupWare-cvs mailing list
