Author: ralfbecker
New Revision: 56042
URL: http://svn.stylite.de/viewvc/egroupware?rev=56042&view=rev
a couple of fixes for pixelegg template for minimal install
trunk/pixelegg/css/mobile.less
trunk/pixelegg/head_mobile.tpl
trunk/pixelegg/hook_settings.inc.php
trunk/pixelegg/less/def_buttons.less
trunk/pixelegg/less/def_design_pattern_color_font_shadow.less
trunk/pixelegg/less/layout_content_elements.less
trunk/pixelegg/less/layout_messages.less
trunk/pixelegg/less/layout_tutorials.less
trunk/pixelegg/less/traditional.less
— trunk/pixelegg/css/mobile.less (original)
+++ trunk/pixelegg/css/mobile.less Thu May 5 20:27:07 2016
@@ -65,7 +65,7 @@
position: absolute;
width: 100%;
height: 100%;
— trunk/pixelegg/head_mobile.tpl (original)
+++ trunk/pixelegg/head_mobile.tpl Thu May 5 20:27:07 2016
@@ -11,7 +11,7 @@
— trunk/pixelegg/hook_settings.inc.php (original)
+++ trunk/pixelegg/hook_settings.inc.php Thu May 5 20:27:07 2016
@@ -13,7 +13,7 @@
@todo extend Stylite template preferences instead of this copy (simple include fails)
$apps = $no_navbar_apps = array();
-if (!$hook_data[‘setup’]) // does not work on setup time
+if (!$hook_data[‘setup’] && !isset($GLOBALS[‘egw_setup’])) // does not work on setup time
foreach(ExecMethod(‘pixelegg.pixelegg_framework.navbar_apps’) as $app => $data)
— trunk/pixelegg/less/def_buttons.less (original)
+++ trunk/pixelegg/less/def_buttons.less Thu May 5 20:27:07 2016
@@ -8,7 +8,7 @@
@package pixelegg
@version $Id$
— trunk/pixelegg/less/def_design_pattern_color_font_shadow.less (original)
+++ trunk/pixelegg/less/def_design_pattern_color_font_shadow.less Thu May 5 20:27:07 2016
@@ -8,7 +8,7 @@
@package pixelegg
@version $Id$
— trunk/pixelegg/less/layout_content_elements.less (original)
+++ trunk/pixelegg/less/layout_content_elements.less Thu May 5 20:27:07 2016
@@ -8,7 +8,7 @@
@package pixelegg
@version $Id$
@import (reference) “definitions.less”;
— trunk/pixelegg/less/layout_messages.less (original)
+++ trunk/pixelegg/less/layout_messages.less Thu May 5 20:27:07 2016
@@ -8,7 +8,7 @@
@package pixelegg
@version $Id$
— trunk/pixelegg/less/layout_tutorials.less (original)
+++ trunk/pixelegg/less/layout_tutorials.less Thu May 5 20:27:07 2016
@@ -8,7 +8,7 @@
@package pixelegg
@version $Id$
— trunk/pixelegg/less/traditional.less (original)
+++ trunk/pixelegg/less/traditional.less Thu May 5 20:27:07 2016
@@ -11,7 +11,7 @@
@package pixelegg
@version $Id$
eGroupWare-cvs mailing list
