Author: ralfbecker
New Revision: 56052
URL: http://svn.stylite.de/viewvc/egroupware?rev=56052&view=rev
admin was using non-pixelegg icon for applications and use of phpgwapi/nonav icon
Added:
trunk/egroupware/api/templates/default/images/nonav.png
- copied unchanged from r56033, trunk/phpgwapi/templates/idots/images/nonav.png
Removed:
trunk/admin/inc/class.admin_ui.inc.php
— trunk/admin/inc/class.admin_ui.inc.php (original)
+++ trunk/admin/inc/class.admin_ui.inc.php Fri May 6 09:59:43 2016
@@ -400,8 +400,8 @@
$path .= ($path == ‘/’ ? ‘’ : ‘/’).$part;
if (!isset($parent[$path]))
$icon = Etemplate\Widget\Tree::imagePath($part == 'apps' ? Api\Image::find('phpgwapi', 'home') :
(($i=Api\Image::find($part, 'navbar')) ? $i : Api\Image::find('phpgwapi', 'nonav')));
$icon = Etemplate\Widget\Tree::imagePath($part == 'apps' ? Api\Image::find('api', 'home') :
(($i=Api\Image::find($part, 'navbar')) ? $i : Api\Image::find('api', 'nonav')));
$parent[$path] = array(
'id' => $path,
'text' => $part == 'apps' ? lang('Applications') : lang($part),
eGroupWare-cvs mailing list
