Author: ralfbecker
New Revision: 56086
URL: http://svn.stylite.de/viewvc/egroupware?rev=56086&view=rev
port “Admin Queue and History” and “Remote Administration Instances” to eT2
trunk/admin/inc/class.admin_cmds.inc.php
trunk/admin/inc/class.admin_hooks.inc.php
trunk/admin/templates/default/cmds.xet
trunk/admin/templates/default/remotes.xet
— trunk/admin/inc/class.admin_cmds.inc.php (original)
+++ trunk/admin/inc/class.admin_cmds.inc.php Sat May 7 18:57:18 2016
@@ -11,6 +11,7 @@
use EGroupware\Api;
+use EGroupware\Api\Etemplate;
- UI for the admin comand queue
@@ -47,7 +48,13 @@
catch (Exception $e) {
$row[‘title’] = $e->getMessage();
$row['data'] = !($data = json_php_unserialize($row['data'])) ? '' :
json_encode($data, JSON_PRETTY_PRINT|JSON_UNESCAPED_UNICODE|JSON_UNESCAPED_SLASHES);
if ($row['status'] == admin_cmd::scheduled)
$row['class'] = 'AllowDelete';
//_debug_array($rows);
return $total;
@@ -60,7 +67,7 @@
static function index(array $content=null)
@@ -74,6 +81,9 @@
‘no_cat’ => true, // I disable the cat-selectbox
’order’ => ‘cmd_created’,
‘sort’ => ‘DESC’,
'row_id' => 'id',
'default_cols' => 'title,created,creator,status',
'actions' => self::cmd_actions(),
@@ -95,6 +105,21 @@
- Acctions for command list/index
- As we only allow to delete scheduled command, which we currently can only create via admin-cli,
- I have not (yet) implemented delete of scheduled commands.
- static function cmd_actions()
return array(
- get_rows for remote instances
@param array $query
@@ -114,7 +139,7 @@
static function remotes(array $content=null)
@@ -128,7 +153,8 @@
’order’ => ‘remote_name’,
‘sort’ => ‘ASC’,
@@ -137,12 +163,17 @@
//_debug_array($content);
unset($content[‘msg’]);
if ($content['nm']['rows']['edit'])
list($id) = each($content['nm']['rows']['edit']);
unset($content['nm']['rows']);
$content['remote'] = admin_cmd::read_remote($id);
if ($content['nm']['action'])
switch($content['nm']['action'])
case 'edit':
$content['remote'] = admin_cmd::read_remote($content['nm']['selected'][0]);
break;
case 'add':
$content['remote'] = array('remote_domain' => 'default');
unset($content['nm']['action']);
elseif($content['remote']['button'])
@@ -180,6 +211,34 @@
$tpl->exec(‘admin.admin_cmds.remotes’,$content,array(),array(),$content);
— trunk/admin/inc/class.admin_hooks.inc.php (original)
+++ trunk/admin/inc/class.admin_hooks.inc.php Sat May 7 18:57:18 2016
@@ -133,8 +133,8 @@
$file[‘phpInfo’] = “javascript:egw.openPopup(’” . Egw::link(’/admin/phpinfo.php’,’’,false) . “’,960,600,‘phpinfoWindow’)”;
$file['Admin queue and history'] = Egw::link('/index.php','menuaction=admin.admin_cmds.index');
$file['Remote administration instances'] = Egw::link('/index.php','menuaction=admin.admin_cmds.remotes');
$file['Admin queue and history'] = Egw::link('/index.php','menuaction=admin.admin_cmds.index&ajax=true');
$file['Remote administration instances'] = Egw::link('/index.php','menuaction=admin.admin_cmds.remotes&ajax=true');
$file['Custom translation'] = Egw::link('/index.php','menuaction=admin.admin_customtranslation.index');
$file['Changelog and versions'] = Egw::link('/about.php');
— trunk/admin/templates/default/cmds.xet (original)
+++ trunk/admin/templates/default/cmds.xet Sat May 7 18:57:18 2016
@@ -5,14 +5,13 @@
<column/>
<column/>
<column/>
<column/>
<column/>
@@ -20,33 +19,27 @@
<nextmatch-sortheader label="Created" id="cmd_created"/>
<nextmatch-accountfilter id="creator" options="Creator"/>
<nextmatch-filterheader id="status" options="Status"/>
<nextmatch-sortheader label="Modified" id="cmd_modified"/>
<nextmatch-sortheader label="Created" id="created"/>
<nextmatch-accountfilter empty_label="Creator" id="creator"/>
<nextmatch-filterheader empty_label="Status" id="status"/>
<nextmatch-sortheader label="Modified" id="modified"/>
<nextmatch-accountfilter options="Modifier" id="modifier"/>
<row class="row $row_cont[class]">
<description id="${row}[title]" statustext="$row_cont[data]"/>
<url-email id="${row}[requested]" options=",,,$row_cont[requested_email]" readonly="true"/>
<date-time id="${row}[scheduled]" readonly="true"/>
<url-email id="${row}[creator]" options=",,,$row_cont[creator_email]" readonly="true"/>
<vbox options="0,0">
<menulist>
<menupopup id="${row}[status]" readonly="true"/>
</menulist>
<select-account id="${row}[creator]" readonly="true" statustext="$row_cont[creator_email]"/>
<vbox>
<select id="${row}[status]" readonly="true"/>
<description id="${row}[error]" class="redItalic"/>
</vbox>
<date-time id="${row}[modified]" readonly="true"/>
<url-email id="${row}[modifier]" readonly="true" options=",,,$row_cont[modifier_email]"/>
<button image="delete" label="Cancel" id="delete[$row_cont[id]]" statustext="Cancel this scheduled command" onclick="et2_dialog.confirm(widget,'Cancel this scheduled command','Cancel');"/>
— trunk/admin/templates/default/remotes.xet (original)
+++ trunk/admin/templates/default/remotes.xet Sat May 7 18:57:18 2016
@@ -41,19 +41,15 @@
@@ -63,18 +59,17 @@
<description value="Actions"/>
</row>
<row class="row">
<description id="${row}[remote_name]"/>
<description options=",$row_cont[remote_url]/?domain=$row_cont[remote_domain],,,_blank" id="${row}[remote_url]"/>
<description id="${row}[remote_domain]" no_lang="1"/>
<hbox align="center">
<button image="edit" label="Edit" id="edit[$row_cont[remote_id]]"/>
</hbox>
</row>
</rows>
</grid>
@@ -82,17 +77,11 @@
<row disabled="!@msg">
<description span="all" class="redItalic" id="msg"/>
</row>
<row disabled="!@remote">
<template content="remote" span="all" class="border" id="admin.remotes.edit"/>
</row>
<row disabled="1">
<template align="right" id="admin.remotes.header_right"/>
</row>
<row>
<nextmatch id="nm" options="admin.remotes.rows"/>
eGroupWare-cvs mailing list
