Author: nathangray
New Revision: 56095
URL: http://svn.stylite.de/viewvc/egroupware?rev=56095&view=rev
Keep customfilter fields together in print column selection dialog
trunk/egroupware/api/templates/default/nm_print_dialog.xet
— trunk/egroupware/api/templates/default/nm_print_dialog.xet (original)
+++ trunk/egroupware/api/templates/default/nm_print_dialog.xet Mon May 9 21:36:13 2016
@@ -4,7 +4,7 @@
Mobile security can be enabling, not merely restricting. Employees who
bring their own devices (BYOD) to work are irked by the imposition of MDM
restrictions. Mobile Device Manager Plus allows you to control only the
apps on BYO-devices by containerizing them, leaving personal data untouched!
https://ad.doubleclick.net/ddm/clk/304595813;131938128;j
eGroupWare-cvs mailing list
