Author: ralfbecker
New Revision: 56120
URL: http://svn.stylite.de/viewvc/egroupware?rev=56120&view=rev
move translationtools to (old) etemplate package
Added:
trunk/etemplate/inc/class.bolangfile.inc.php
- copied, changed from r56115, trunk/developer_tools/inc/class.bolangfile.inc.php
trunk/etemplate/inc/class.uilangfile.inc.php
- copied, changed from r56115, trunk/developer_tools/inc/class.uilangfile.inc.php
trunk/etemplate/lang/ (props changed)
- copied from r56115, trunk/developer_tools/lang/
trunk/etemplate/templates/default/addphrase.tpl
- copied unchanged from r56115, trunk/developer_tools/templates/default/addphrase.tpl
trunk/etemplate/templates/default/applications.tpl
- copied unchanged from r56115, trunk/developer_tools/templates/default/applications.tpl
trunk/etemplate/templates/default/langfile.tpl
- copied unchanged from r56115, trunk/developer_tools/templates/default/langfile.tpl
trunk/etemplate/templates/default/langmissing.tpl
- copied unchanged from r56115, trunk/developer_tools/templates/default/langmissing.tpl
trunk/etemplate/inc/class.solangfile.inc.php
trunk/etemplate/inc/hook_sidebox_menu.inc.php
— trunk/developer_tools/inc/class.bolangfile.inc.php (original)
+++ trunk/etemplate/inc/class.bolangfile.inc.php Wed May 11 14:43:23 2016
@@ -6,7 +6,8 @@
@package translationtools
@subpackage translationtools
@version $Id$
— trunk/etemplate/inc/class.solangfile.inc.php (original)
+++ trunk/etemplate/inc/class.solangfile.inc.php Wed May 11 14:43:23 2016
@@ -6,7 +6,8 @@
@version $Id$
— trunk/developer_tools/inc/class.uilangfile.inc.php (original)
+++ trunk/etemplate/inc/class.uilangfile.inc.php Wed May 11 14:43:23 2016
@@ -6,7 +6,8 @@
@version $Id$
@@ -45,8 +46,8 @@
$this->template = $GLOBALS[‘egw’]->template;
$this->template->egroupware_hack = False; // else the phrases got translated
@@ -81,7 +82,7 @@
if (!$_POST[‘more’])
$GLOBALS[‘egw’]->redirect_link(’/index.php’,array(
'menuaction' => 'etemplate.uilangfile.edit',
'app_name' => $app_name,
'sourcelang' => $sourcelang,
'targetlang' => $targetlang
@@ -94,7 +95,7 @@
common::egw_header();
echo parse_navbar();
$this->template->set_var('form_action',$GLOBALS['egw']->link('/index.php','menuaction=etemplate.uilangfile.addphrase'));
$this->template->set_var('sourcelang',$sourcelang);
$this->template->set_var('targetlang',$targetlang);
$this->template->set_var('app_name',$app_name);
@@ -130,7 +131,7 @@
// we have to redirect here, as solangfile defines function sidebox_menu, which clashes with the iDots func.
'menuaction' => 'etemplate.uilangfile.missingphrase2',
@@ -188,7 +189,7 @@
$this->bo->save_sessiondata();
$GLOBALS['egw']->redirect_link('/index.php',array(
@@ -202,7 +203,7 @@
$this->template->set_var(‘lang_update’,lang(‘Add’));
$this->template->set_var(‘lang_view’,lang(‘Cancel’));
$this->template->set_var('action_url',$GLOBALS['egw']->link('/index.php','menuaction=etemplate.uilangfile.missingphrase2'));
@@ -216,7 +217,7 @@
$this->template->set_var(‘view_link’,
$GLOBALS[‘egw’]->link(
’/index.php’,
@@ -240,7 +241,7 @@
if ($_POST[‘cancel’])
$GLOBALS['egw']->redirect_link('/index.php','menuaction=etemplate.uilangfile.index');
$app_name = get_var('app_name',array('POST','GET'));
$sourcelang = get_var('sourcelang',array('POST','GET'));
@@ -250,7 +251,7 @@
if($_POST[‘addphrase’] || $_POST[‘missingphrase’])
'menuaction' => 'etemplate.uilangfile.'.($_POST['addphrase']?'addphrase':'missingphrase'),
@@ -281,7 +282,7 @@
$this->template->set_block(‘langfile’,‘detail_long’,‘detail_long’);
$this->template->set_block(‘langfile’,‘footer’,‘footer’);
$this->template->set_var('action_url',$GLOBALS['egw']->link('/index.php','menuaction=etemplate.uilangfile.edit'));
$this->template->set_var('lang_remove',lang('Remove'));
$this->template->set_var('lang_application',lang('Application'));
$this->template->set_var('lang_source',lang('Source Language'));
@@ -581,14 +582,14 @@
$limit = $total;
$this->template->set_var('sort_title',$this->nextmatchs->show_sort_order($sort,'title','title','/index.php',lang('Title'),'&menuaction=developer_tools.uilangfile.index'));
$this->template->set_var('sort_title',$this->nextmatchs->show_sort_order($sort,'title','title','/index.php',lang('Title'),'&menuaction=etemplate.uilangfile.index'));
$this->template->set_var('lang_showing',$this->nextmatchs->show_hits($total,$start));
$this->template->set_var('left',$this->nextmatchs->left('/index.php',$start,$total,'&menuaction=developer_tools.uilangfile.index'));
$this->template->set_var('right',$this->nextmatchs->right('/index.php',$start,$total,'&menuaction=developer_tools.uilangfile.index'));
$this->template->set_var('left',$this->nextmatchs->left('/index.php',$start,$total,'&menuaction=etemplate.uilangfile.index'));
$this->template->set_var('right',$this->nextmatchs->right('/index.php',$start,$total,'&menuaction=etemplate.uilangfile.index'));
$this->template->set_var('lang_edit',lang('Edit'));
//$this->template->set_var('lang_translate',lang('Translate'));
$this->template->set_var('new_action',$GLOBALS['egw']->link('/index.php','menuaction=etemplate.uilangfile.create'));
$this->template->set_var('create_new',lang('Create New Language File'));
$i = 0;
@@ -600,8 +601,8 @@
$this->template->set_var('name',$data['title']);
$this->template->set_var('edit','<a href="' . $GLOBALS['egw']->link('/index.php','menuaction=developer_tools.uilangfile.edit&app_name=' . urlencode($data['name'])) . '"> ' . lang('Edit') . ' </a>');
// $this->template->set_var('translate','<a href="' . $GLOBALS['egw']->link('/index.php','menuaction=developer_tools.uilangfile.translate&app_name=' . urlencode($app['name'])) . '"> ' . lang('Translate') . ' </a>');
$this->template->set_var('edit','<a href="' . $GLOBALS['egw']->link('/index.php','menuaction=etemplate.uilangfile.edit&app_name=' . urlencode($data['name'])) . '"> ' . lang('Edit') . ' </a>');
// $this->template->set_var('translate','<a href="' . $GLOBALS['egw']->link('/index.php','menuaction=etemplate.uilangfile.translate&app_name=' . urlencode($app['name'])) . '"> ' . lang('Translate') . ' </a>');
$this->template->set_var('status',$status);
— trunk/etemplate/inc/hook_sidebox_menu.inc.php (original)
+++ trunk/etemplate/inc/hook_sidebox_menu.inc.php Wed May 11 14:43:23 2016
@@ -18,7 +18,7 @@
$file += array(
‘NewLine’, // give a newline
Propchange: trunk/etemplate/lang/
— svn:ignore (added)
+++ svn:ignore Wed May 11 14:43:23 2016
@@ -1,0 +1,37 @@
+egw_bg.lang.old
+egw_ca.lang.old
+egw_cs.lang.old
+egw_da.lang.old
+egw_de.lang.old
+egw_el.lang.old
+egw_es-es.lang.old
+egw_et.lang.old
+egw_eu.lang.old
+egw_fa.lang.old
+egw_fi.lang.old
+egw_fr.lang.old
+egw_hi.lang.old
+egw_hr.lang.old
+egw_hu.lang.old
+egw_id.lang.old
+egw_it.lang.old
+egw_iw.lang.old
+egw_ja.lang.old
+egw_ko.lang.old
+egw_lo.lang.old
+egw_lt.lang.old
+egw_lv.lang.old
+egw_nl.lang.old
+egw_no.lang.old
+egw_pl.lang.old
+egw_pt-br.lang.old
+egw_pt.lang.old
+egw_ru.lang.old
+egw_sk.lang.old
+egw_sl.lang.old
+egw_sv.lang.old
+egw_tr.lang.old
+egw_uk.lang.old
+egw_vi.lang.old
+egw_zh-tw.lang.old
+egw_zh.lang.old
Mobile security can be enabling, not merely restricting. Employees who
bring their own devices (BYOD) to work are irked by the imposition of MDM
restrictions. Mobile Device Manager Plus allows you to control only the
apps on BYO-devices by containerizing them, leaving personal data untouched!
https://ad.doubleclick.net/ddm/clk/304595813;131938128;j
eGroupWare-cvs mailing list
