Author: hnategh
New Revision: 56126
URL: http://svn.stylite.de/viewvc/egroupware?rev=56126&view=rev
Fix wrong navbar icon used as navbar.svg in calendar
trunk/calendar/templates/mobile/images/navbar.svg
trunk/calendar/templates/pixelegg/images/navbar.svg
— trunk/calendar/templates/mobile/images/navbar.svg (original)
+++ trunk/calendar/templates/mobile/images/navbar.svg Wed May 11 16:36:10 2016
@@ -1,26 +1,22 @@
<?xml version="1.0" encoding="utf-8"?>
-<?xml-stylesheet type="text/css" href="../../../../pixelegg/less/svg.css" ?>
-<svg version=“1.1” id=“calendar_navbar” xmlns=“http://www.w3.org/2000/svg” xmlns:xlink=“http://www.w3.org/1999/xlink” x=“0px” y=“0px”
- width=“32px” height=“32px” viewBox=“0 0 32 32” enable-background=“new 0 0 32 32” xml:space=“preserve”>
- <path fill-rule=“evenodd” clip-rule=“evenodd” fill="#CC0033" d="M18.804,8.086c0.888,0,1.607-0.721,1.607-1.608V4.067
c0-0.89-0.72-1.609-1.607-1.609c-0.89,0-1.608,0.72-1.608,1.609v2.411C17.196,7.366,17.915,8.086,18.804,8.086z"/>
- <path fill-rule=“evenodd” clip-rule=“evenodd” fill="#CC0033" d="M9.259,8.086c0.891,0,1.609-0.721,1.609-1.608V4.067
c0-0.89-0.719-1.609-1.609-1.609c-0.887,0-1.606,0.72-1.606,1.609v2.411C7.653,7.366,8.373,8.086,9.259,8.086z"/>
- <path fill-rule=“evenodd” clip-rule=“evenodd” fill="#CC0033" d="M8.807,20.488c0,2.689,2.262,2.871,3.104,2.871
c1.799,0,3.044-1.15,3.044-2.775c0-1.467-1.032-1.916-1.345-2.002v-0.023c0.502-0.217,1.067-0.764,1.067-1.637
c0-1.818-1.572-2.4-2.767-2.4c-2.011,0-2.954,1.15-2.954,2.763h1.634c0-0.305,0-1.406,1.206-1.406c0.969,0,1.12,0.787,1.12,1.102
c0,1.117-0.969,1.168-1.497,1.168h-0.275v1.211c0.816,0,2,0.049,2,1.225c0,0.957-0.618,1.418-1.321,1.418
c-1.183,0-1.309-1.043-1.309-1.504l0.014-0.01H8.807z"/>
- <path fill-rule=“evenodd” clip-rule=“evenodd” fill="#CC0033" d="M22.066,4.874h-0.642v2.582c0,0.965-0.781,1.748-1.746,1.748
h-1.749c-0.965,0-1.747-0.783-1.747-1.748V4.874h-4.3v2.582c0,0.965-0.781,1.748-1.747,1.748H8.387
c-0.966,0-1.747-0.783-1.747-1.748V4.874H5.998c-2.001,0-3.619,1.622-3.619,3.616v0.003v14.466c0,1.996,1.618,3.615,3.619,3.615
h16.068c1.997,0,3.62-1.619,3.62-3.615V8.493V8.49C25.686,6.496,24.063,4.874,22.066,4.874z M23.255,22.895
c0,0.596-0.482,1.084-1.081,1.084H6.041c-0.598,0-1.084-0.488-1.084-1.084v-9.343h18.299V22.895z"/>
- <path fill-rule=“evenodd” clip-rule=“evenodd” fill="#CC0033" d="M17.497,23.129h1.761v-8.607h-1.446
c-0.036,0.643-0.489,1.492-2.185,1.492h-0.253v1.188h2.123V23.129z"/>
<path fill="#CC0033" stroke-miterlimit="10" d="M11.125,7.5c1.104,0,2-0.896,2-2v-3c0-1.104-0.896-2-2-2
s-2,0.896-2,2v3C9.125,6.604,10.021,7.5,11.125,7.5z M25.125,7.5c1.104,0,2-0.896,2-2v-3c0-1.104-0.896-2-2-2s-2,0.896-2,2v3
C23.125,6.604,24.021,7.5,25.125,7.5z M29.125,3.5h-1v3c0,1.105-0.896,2-2,2h-2c-1.104,0-2-0.896-2-2v-3h-8v3c0,1.105-0.896,2-2,2
h-2c-1.104,0-2-0.896-2-2v-3h-1c-1.104,0-2,0.896-2,2v11.262c0.64-0.165,1.308-0.262,2-0.262c0.34,0,0.672,0.028,1,0.069V16.5h6
v4.13c0.636,1.147,1,2.466,1,3.87v-2h6v5h-6v-3c0,2.393-1.056,4.534-2.721,6h16.721c1.104,0,2-0.896,2-2v-23
C31.125,4.396,30.229,3.5,29.125,3.5z M14.125,15.5h-6v-5h6V15.5z M21.125,21.5h-6v-5h6V21.5z M21.125,15.5h-6v-5h6V15.5z
M28.125,27.5h-6v-5h6V27.5z M28.125,21.5h-6v-5h6V21.5z M28.125,15.5h-6v-5h6V15.5z M7.125,18.508
c-3.309,0-5.992,2.684-5.992,5.992s2.683,5.991,5.992,5.991c3.309,0,5.991-2.683,5.991-5.991S10.434,18.508,7.125,18.508z
M10.793,24.027l-3.836,3.195c-0.129,0.107-0.283,0.171-0.445,0.213c-0.1,0.033-0.2,0.053-0.303,0.049
c-0.284,0.004-0.569-0.081-0.786-0.262c-0.154-0.128-0.232-0.288-0.274-0.453l-0.784-0.783c-0.344-0.344-0.344-0.902,0-1.246
c0.344-0.344,0.902-0.344,1.246,0l0.571,0.572l3.075-2.564c0.424-0.353,1.111-0.353,1.535,0
C11.216,23.102,11.216,23.674,10.793,24.027z"/>
— trunk/calendar/templates/pixelegg/images/navbar.svg (original)
+++ trunk/calendar/templates/pixelegg/images/navbar.svg Wed May 11 16:36:10 2016
@@ -1,26 +1,22 @@
- <path fill-rule=“evenodd” clip-rule=“evenodd” fill="#696969" d="M18.804,8.086c0.888,0,1.607-0.721,1.607-1.608V4.067
- <path fill-rule=“evenodd” clip-rule=“evenodd” fill="#696969" d="M9.259,8.086c0.891,0,1.609-0.721,1.609-1.608V4.067
- <path fill-rule=“evenodd” clip-rule=“evenodd” fill="#696969" d="M8.807,20.488c0,2.689,2.262,2.871,3.104,2.871
- <path fill-rule=“evenodd” clip-rule=“evenodd” fill="#696969" d="M22.066,4.874h-0.642v2.582c0,0.965-0.781,1.748-1.746,1.748
- <path fill-rule=“evenodd” clip-rule=“evenodd” fill="#696969" d="M17.497,23.129h1.761v-8.607h-1.446
<path fill="none" stroke="#62686A" stroke-miterlimit="10" d="M11.125,7.5c1.104,0,2-0.896,2-2v-3c0-1.104-0.896-2-2-2
Mobile security can be enabling, not merely restricting. Employees who
bring their own devices (BYOD) to work are irked by the imposition of MDM
restrictions. Mobile Device Manager Plus allows you to control only the
apps on BYO-devices by containerizing them, leaving personal data untouched!
https://ad.doubleclick.net/ddm/clk/304595813;131938128;j
eGroupWare-cvs mailing list
