Author: ralfbecker
New Revision: 56138
URL: http://svn.stylite.de/viewvc/egroupware?rev=56138&view=rev
Changelog for 14.3.20160612
branches/14.2/egroupware/doc/rpm-build/debian.changes
— branches/14.2/egroupware/doc/rpm-build/debian.changes (original)
+++ branches/14.2/egroupware/doc/rpm-build/debian.changes Wed May 18 21:41:53 2016
@@ -1,3 +1,23 @@
+egroupware-epl (14.3.20160612) hardy; urgency=low
- TranslationTools: move remaining code from developer_tools directory to etemplate, accessible now only through link in etemplate sidebox menu
- Mail/Addressbook/Calendar: add and use charset when sending/receiving mails with vCard/iCals, change default vCard charset preference to utf-8
- Import/Export: Fix export with multi-select customfields does not work
- Addressbook: adding “Lastname, Firstname (birthday)” as fileas and link-title
- Preferences/CKEditor: Remove unsupported skins from CKEditor
- – Ralf Becker rb@stylite.de Wed, 18 May 2016 21:41:33 +0200
- – Ralf Becker rb@stylite.de Wed, 18 May 2016 21:40:38 +0200
egroupware-epl (14.3.20160428) hardy; urgency=low
- CardDAV: fix not working creation of new CardDAV account with OS X 10.11.4 addressbook (it stays empty)
Mobile security can be enabling, not merely restricting. Employees who
bring their own devices (BYOD) to work are irked by the imposition of MDM
restrictions. Mobile Device Manager Plus allows you to control only the
apps on BYO-devices by containerizing them, leaving personal data untouched!
https://ad.doubleclick.net/ddm/clk/304595813;131938128;j
eGroupWare-cvs mailing list
