1 / 18
Jan 2021
with the today RC didn’t start an videosession.
I tried diffrent jitsi provider.
Initilasation seems to work:
But then only this
There isn’t the Chat entry with the blue button and the new window didn’t start.
I got the issue even over client and direct in the groupware session.
the RC server version is 3.10.0
When I use the egroupware calendar the Videsession work, sure, this didn’t use RC.
Is this reproduceable for other?
yes, this is the same issue. There is an issue for the 3.93. and BBB too:
I’ve image: quay.io/egroupware/rocket.chat:stable
in my yaml. seems not so stable,…
But I wonder why I got 3.10.0? Shouldn’t it 3.9.4?
It should better I pin it static,…
Please take a look into
/etc/egroupware-rocketchat/docker-compose.override.yml
What is entered there has relevance. Unless it is commented out…
See also
This is exactly what we wanted to achieve with the last package update.
Did you install it?
@RalfBecker
Can we (in future) mark the version we released last as stable? I would find that more logical.
yes, I’ve make a mistake in the override is written latest.
Did you think I could made an downgrade? It should work, if there is no MongoDB changes it should work with pin 3.9.3 and made an new pull?
I don’t know…
Especially with Rocket.Chat, I think this is problematic. That’s why we also wanted to pin to a version that we have tested (as far as possible).
There are new features with new database entrys(?):
I would try it (after a full backup).
I build all versions, and only mark the latest tested one as stable, currently 3.9.4, I have not tested (yet) with 3.10.0.
I’ve managed to downgrade in my private test installation without problem.
Then I downgrade our production at the weekend.
They push two new releases, with the newest one it work.
Now I’ve to pin it,…
wie ich vorhin mit Stefan festgestellt hatte hatte ich in der docker-compose.override.yml nicht Eure Quelle, sondern die von Rocket Chat selbst drin:
#image: rocketchat/rocket.chat:latest
Dadruch hatte ich dann auch die 3.10er erhalten.
Nein, weil Du schon auf 3.10 bist, und downgrades mit Rocket.Chat im allg. nicht funktionieren (wegen Datenbankschema), tragen wir unseren Container mit dem stable-Tag nur ein, wenn Du eine Version kleiner oder gleich unserer aktuellen stable Version (aktuell 3.9.3) verwendest.
Ich habe jetzt mal ein bisschen mit 3.10.3 getestet und scheint soweit alles zu funktionieren.
Ich habe mit einen weiteren Proxy von /avatar --> /rocketchat/avatar im neuen egroupware-rocketchat Paket von gerade eben (3.10.20210112) auch das kaputte eigene Avatar Bild gefixed.
Das Paket versucht auch wieder die Installationen auf das Image quay.io/egroupware/rocket.chat:stable umzustellen.
Paket installiert: Funktioniert so weit, stable ist eingetragen.
Mein (und auch die anderen) Avatar wird aber nicht angezeigt. Muss ich etwas neu starten/leeren/resetten ?..
@grefabu
Die Sache mit der Anzeige “Update your Rocket.Chat…”:
grafik
Ist unabhängig von der installierten Version. Du musst das (als Admin) eh quittieren. Eins nach dem anderen…
@RalfBecker
Ob die Anzeige “Database Migration” den "Versionsstand der Datenbank anzeigt? Dann wäre das als Hinweis zu nehmen ob man ein downgrade machen kann oder nicht. Von der 3.10 auf die 3.9 ging das in dem Fall/Moment.
split this topic Jan 12, '21
A post was split to a new topic: Avatar wird nicht in RC angezeigt
