Hi, greno,
I had done some preliminary tests on (eGW1.4beta1 + CK-ERP). Your
problem is definitely due to enhancements made to eGW1.4beta1. So, for
the moment,
eGW1.2-106 + CK-ERP 0.21.1 - works fine.
eGW1.4beta1 + CK-ERP 0.21.1 - will fail. New eGW connector will be
released post full system integration test to catch all incompatibilities.
Cheers,
CK
C K Wu wrote:
Hi, greno,
Thank you for your interest in CK-ERP.
CK-ERP had not been tested against eGW 1.4beta1, which if I remember
correctly, was released just yesterday. So, you may find it to be a
bumpy ride installing CK-ERP within eGW 1.4beta1, although I do plan
to test out (CK-ERP + eGW 1.4beta1) within the next few days. Staying
with the last stable release of eGW would be a better alternative for
the moment.
The following excerpt from CK-ERP’s Installation Manual, may be of
assistance, here,
- Login egroupware, xoops, joomla, mambo, drupal, zencart, creloaded,
oscommerce, xaraya, horde, tikiwiki or phpbb as admin level user.
DO NOT LOGIN AS NON-ADMIN USER.
So, it could be a non-admin level login or some unexpected
modifications/enhancements of eGW 1.4beta1 that does not sit well with
CK-ERP.
Cheers,
CK
greno wrote:
I installed CK-ERP in eGW 1.4beta1 and when I click on the castle icon
as an admin user it gives me this warning:
Warning: Variable passed to each() is not an array or object in /opt/
lampp/htdocs/egroupware/ck-api/egw/connector.inc.php on line 112
You are not authorised to access the requested information.*
Of course clicking on any other icon says xxxx table not found type
error.
How to fix?
thx,
greno
You received this message because you are subscribed to the Google
Groups “CK-ERP (English)” group.
To post to this group, send email to CK-ERP-en@googlegroups.com
To unsubscribe from this group, send email to
CK-ERP-en-unsubscribe@googlegroups.com
For more options, visit this group at
http://groups-beta.google.com/group/CK-ERP-en
Get stuff done quickly with pre-integrated technology to make your job easier.
