Hi Selso,
Hello !
When editing project, we sometimes have an unwanted projet linked to
the edited one.
We found out that when adding a member, if a project has the same ID
of the member, a link to this projet is configured in the link tab,
and automatically added when saving.
Sorry, let me try to clarify what your saying: if you add a member
(user) to a project and he has incidentally the same numeric (database)
id as an other project, that project would be linked to the project you
are adding a member to.
Is the above what you want to express?
Yes, it is all about the database ID.
Example :
Suppose you are editing projet no 15100 to add member selso (database
id = 30), and if another project with no 15200 (or whatever) and
database id = 30, then this project will be linked at the same time as
the member added.
In fact this linked project is selected, and in the code we found
some code that automically adds selected project. We just deleted this
code in order to avoid that.
Can you please post a diff of the code you deleted, then I can see if I
can reproduce and fix it.
