If you use a username of eg. “blah” in EGroupware you have to choose
"Virtual Mail Manager" AND set the domain “blah.com”, to get EGroupware
to conntect with "blah@blah.com" to your IMAP server.
Maybe that’s your problem.
madsurgeon schrieb:
Hi all
I cannot get a working connection from egw to my dovecot IMAP server. I
receive the following error message, no matter of the configuration:
The connection to the IMAP Server failed!!
When testing with the script /felamimail/testimapserver.php all looks fine.
The logs from /var/log/dovecot-info.log when connecting with
/felamimail/testimapserver.php look fine:
dovecot: Sep 22 15:05:01 Info: auth(default): client out: CONT 1 V…
dovecot: Sep 22 15:05:01 Info: auth(default): client in: CONT 1 Y…
dovecot: Sep 22 15:05:01 Info: auth(default): client out: CONT 1 U…
dovecot: Sep 22 15:05:01 Info: auth(default): client in: CONT 1 T…
passwd-file(blah@blah.com,127.0.0.1): lookup: user=blah@blah.com
file=/etc/dovecot/passwd
dovecot: Sep 22 15:05:01 Info: auth(default): client out: OK 1
user=blah@blah.com
5328cot:1Sep 22 15:05:01 Info: auth(default): master in: REQUEST 65
dovecot: Sep 22 15:05:01 Info: auth(default): master out: USER 65
blah@blah.com uid=111 gid=8 home=/srv/vmail/blah.com/blah
dovecot: Sep 22 15:05:01 Info: imap-login: Login: user=blah@blah.com,
method=LOGIN, rip=127.0.0.1, lip=217.150.250.xxx, TLS
dovecot: Sep 22 15:05:01 Info: IMAP(blah@blah.com): Disconnected: Logged out
dovecot: Sep 22 15:05:02 Info: auth(default): new auth connection: pid=8799
However, after trying to access from felamimail insode egw:
dovecot: Sep 22 15:14:32 Info: imap-login: Disconnected: rip=127.0.0.1,
lip=217.
150.250.xxx
dovecot: Sep 22 15:14:32 Info: auth(default): new auth connection: pid=26479
dovecot: Sep 22 15:14:33 Info: imap-login: Disconnected: rip=127.0.0.1,
lip=217.
150.250.xxx
dovecot: Sep 22 15:14:34 Info: auth(default): new auth connection: pid=26487
Why is egw not sending the correct login data? I have set them up in
emailadmin…
David
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
mailto: rb@stylite.de
www.stylite.de
www.egroupware.org
Geschäftsführer Andre Keller,
Gudrun Müller, Ralf Becker
ahead of the curve. Join us from November 9-12, 2009. Register now!
http://p.sf.net/sfu/devconf
