Hi Yves,
I’m not testing and working much with the old community version
(1.6.002). Therefore I gave it a try again this morning: It works well
for me: I can see my calendar and create new events on iPhone.
So I can only speculate it’s a configuration problem on your iPhone or
EGroupware. Just a view pointers:
- check the account url (advanced settings) on iPhone, make sure the
port is correct too (80 for http with use ssl OFF or 443 for https with
use ssl ON)
- check GroupDAV app is enabled in EGroupware (should be as you say
lightning is working)
Otherwise there’s always our commercial support: www.stylite.de
Yves Réveillon - eurower.fr schrieb:
Yes of course, I haven’t applied this patch, I understand that it was
already included in the 1.6.002.
Meanwhile, I cannot “synchronise” with groupdav / caldav beetwen my
iphone and eGroupWare.
By Google, I mean that iphone synchronise with Google.
Lightning synchronize wite eGroupWare
But, iphone don’t synchronise with eGroupWare
I understand that Google act as a caldav server
So the Google caldav implement anything that eGroupWare not implement
and that it is required by iphone, but what.
I don’t understand what is wrong on my egroupware and my iphone.
Ralf Becker a écrit :
That patch is already in 1.6.002:
http://www.egroupware.org/viewvc/egroupware?view=rev&revision=27455
Applying the patch again, might break something …
Hi everyboy,
I’ve installed eGroupWare version 1.6.002, but the patch :
http://www.egroupware.org/viewvc/egroupware?view=rev&revision=27437
seems to don’t work fine with mi iphone 3GS.
But word fine with Lightinng.
More, the caldav work fine with … Google, but with SSL, not possible
to sniff with Wireshark snif :s
What do you mean? Google calendar implementes a CalDAV server like
EGroupware, not a client. Therefore both can NOT talk together.
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
mailto: rb@stylite.de
www.stylite.de
www.egroupware.org
Geschäftsführer Andre Keller,
Gudrun Müller, Ralf Becker
ahead of the curve. Join us from November 9 - 12, 2009. Register now!
http://p.sf.net/sfu/devconference
