Hi the only known way (for me) is to nest projects.If you do that from the
very beginning, your desired view is possible.If you want to do that for
existing projects:Create a new "Container Project"Link all desired Projects
to that Container Project from within the Container Project.After you have
done that, it is possible to view the GantChart for the Container.I hope
this will helpregardsLeithoff, Klaus RayPath sp2ong@wp.pl schrieb:
I have install fresh version 1.2.105. For me main application is
projectmanager. I saw that in new version I can select all listed project
and use gantt chart icon in right bottom corner to display Gantt chart for
selected projects.The Gantt chart was displayed names of projects in leftt
side but bar only for one project. I have setup start and end date for
range
whole projecrs. For me it is very important to see on one display bars for
all selected projects. Is it possible ?
View this message in context:
http://www.nabble.com/-Projectmanager--Gantt-chart-for-many-projects---tf2505809s3741.html#a6986530
Sent from the egroupware-developers mailing list archive at Nabble.com.
Get stuff done quickly with pre-integrated technology to make your job
easier
Klaus Leithoff
23.10.2006
