Hi Raphael,
Raphael Alla schrieb:
I discovered the feature when looking at the code, and found it
convenient as it allows to use the same e-template for both viewing and
editing a form. I started using it in my code and stumbled on the issue
when using “date” widgets.
One of the great things about e-templates is that widgets update the way
they display each other when they are read-only or editable; therefore a
template “looks good” in both situations. In my view this is a useful
feature.
Ok, then let’s make it an official feature.
R.
Hi Raphael,
so far this is only internally used to make whole templates readonly.
Not sure if I want to make that a feature, do you need that?
> Hi,
> An undocumented feature in etemplate seems to be when the key __ALL__
> is set in the readonlys array. This turns the whole template into a
> readonly template, and all entries and inputs are readonly.
> It came however to my attention that this behaviour will not work for
> extensions, as the code only checks whether $readonlys[$name] is set.
> Because the feature is undocumented I am unsure whether this is a bug
> or not.
> An easy way to fix this is to replace line 833 (as per the version of
> CVS head) of etemplate/inc/class.uietemplates.inc.php by something
> along those lines:
> $_readonlys = $readonlys[$name];
> if ($readonlys['__ALL__']) $_readonlys = true;
> $extra_label =
> $this->extensionPreProcess($type,$form_name,$value,$cell,$_readonlys);
> I hope it helps
> Raphael
Using Tomcat but need to do more? Need to support web services,
security?
Get stuff done quickly with pre-integrated technology to make your
job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache
Geronimo
<http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642>
_______________________________________________
<mailto:eGroupWare-developers@lists.sourceforge.net>
Raphael Alla
Mitija Australia
+61 4 15 678 576
http://www.mitija.com http://www.mitija.com
