Both pERP and workflow like to be connected to a database with
transactions. The code to do so for MySQL looks like:
$db = clone($GLOBALS[‘egw’]->db);
$db->disconnect();
$db->connect(
$GLOBALS[‘egw_info’][‘server’][‘db_name’],
$GLOBALS[‘egw_info’][‘server’][‘db_host’],
$GLOBALS[‘egw_info’][‘server’][‘db_port’],
$GLOBALS[‘egw_info’][‘server’][‘db_user’],
$GLOBALS[‘egw_info’][‘server’][‘db_pass’],
‘mysqlt’
return $db;
SVN rev. 25875
Recently (sorry, can’t be more specific), this gives the following
(from pERP, from workflow is pretty much the same):
Warning: include_once(/…/ADOdb/inc/class…inc.php): failed to open
stream: No such file or directory in
/…/phpgwapi/inc/common_functions.inc.php on line 680
Warning: include_once() [function.include: Failed opening
’/…/ADOdb/inc/class…inc.php’ for inclusion
(include_path=’/…/egw-pear:.:/usr/share/php:/usr/share/
pear’) in /…/phpgwapi/inc/common_functions.inc.php on
line 680
CreateObject(‘ADOdb’): Cant instanciate class!!!
bo_perp_api::perp_autoload / call_user_func(Array) / __autoload(ADOdb) /
class_exists(ADOdb) / egw_minimal::__get / egw_db::connect /
bo_perp_api::reconnect_transactional / call_user_func(Array) /
ExecMethod(perp_api.bo_perp_api.reconnect_transactional) /
ReceivableInvoice::post / ui_perp_receivable_invoice::edit /
ExecMethod(perp_ar.ui_perp_receivable_invoice.edit)
/ etemplate::process_exec / call_user_func(Array) /
ExecMethod(etemplate.etemplate.process_exec)
For some reason (session not being properly restored?) it looks like
the egw_minimal::ADOdb object is null (see class.egw.inc.php, 572).
This causes the various autoload functions to be called (eGW’s
autoload first, then pERP’s) looking for ‘ADOdb’, which fails.
Sometimes if you log in, and go to the page that fails immediately, it
works with no problems. The error seems to happen after working for a
while, or if you have been working, log out, then log back in.
Ralf, any tips would be appreciated. I’m not even sure where to start
looking for a fix. Is there something not being done by pERP and
workflow to correctly restore the session, or is there something awry
in the autoloading? It looks like it’s looking for /ADODB/inc/…
instead of /phpgwapi/adodb/… Or something else entirely?
Nathan Gray
nathan at goarctic dot com
