Hi Hans-Juergen,
Hans-Juergen Tappe schrieb:
Hi!
After I had my try with a calendar display module for the sitemgr (for
automated event publishing) with eGroupware 1.4, I’d like to start “from
scratch” for 1.6.
The problems with 1.4 were various, the core problem I faced was the
session management, which keeps some calendar data of the user in the
cache (but if I visit the website while logged in, I don’t want to see
my personal calendar but the public announcements).
eGW’s session management has nothing to do with that.
The calendar UI stores it’s state (which date, view, calendars to show,
etc) in the session. If you which to be independent of that, you can eg.
use eg. calendar_bo::search() direct.
The new approach should be based on existing ical/caldav PHP calendar
viewers and use:
- one (or more) networking calendars
- from a defined user (default: The anonymous user)
- of a defined time scale (multi-week or month view)
- caching of the data found
The CalDAV code in eGW is currently only the server side, it does NOT
help to query any calendar (including your own eGW install). Therefore
you need a CalDAV client.
Using a CalDAV client has it’s advantages, as you can query and display
any CalDAV enabled calendar and not only the ones from the local eGW
installation.
Just googled a bit, but I could NOT find a php CalDAV client libary. You
could go the same way, as I did it for the server: use a general WebDAV
class and extend it for CalDAV.
If developing your own CalDAV client is beyond the scope of your
project, you can come back to calendar_bo::search() (can also be called
via xmlrpc from other eGW installs). It gives you complete control over
what calendars and timespans to display. It does NOT contain any UI
code, that’s call in calendar_uiviews. So you need to decide if you want
to spend time with creating your own views or settle on using the
existing UI code. Having an own state for the sitemgr site and your
personal calendar for logged in users should be possible (maybe it needs
a little work).
Can someone (Ralph, you probably know the caldav code best ) please
point me to a function any prerequisites in order to use internal
functionality to retrieve caldav (or ical) data instead of pulling the
data through the network - but with a fixed user ID?
What would be the URL of a remote calendar to limit view on user and
time frame?
Also, maybe, there is already a framework that can be used for the
caching mechanism?
Thanks a lot,
Hans-Jürgen
Telefon +49 (0)631 31657-0
