Hi Will,
Hello,
I have found a few very old post on this subject but they didn’t have proper
answers in them.
Is there some way of removing very old calendar entries?
I have looked at the sql schema and I’m not quite sure on the relationship
between calendar tables. Before I dive in a break things horribly I wondered
if anyone could tell me what the mysql commands are I want to remove old
entries.
That’s a little tricky, best way is to set a general retention policy in
calendar configuration:
Automatically purge old events after: never or .5 - 10years selectable
It will create a monthly running job, which you can switch off again
after it’s first run, if you don’t want to do it permanently.
