1 / 5
Nov 2021
I have restart my ubuntu server and docker engine, after restart, containers running correctly but rocketchat application don’t start , and show 502 bad gateway , in a server startus show "unable to connect!"
I wanto to try to start rocketchat application manually ,how to start rocketchat application on a container manually?
Where is the logs of the rocketchat server on a container?
Tks
  • created
    Nov '21
  • last reply
    Nov '21
  • 4
  • 1.1k
  • 3
  • 3
    links
Hi Giuseppe.
Please check where you get the Rocket.Chat container from. In the
/etc/egroupware-rocketchat/docker-compose.yml
should contain the following information:
services:
  rocketchat:
    image: quay.io/egroupware/rocket.chat:stable
That means: The container image comes from us:
https://quay.io/repository/egroupware/rocket.chat?tag=latest&tab=tags2
and is tested by us (As far as that is possible…).
And please check also your
/etc/egroupware-rocketchat/docker-compose.override.yml
If possible, the original Rocket.Chat container should not be entered there either. Only if you know exactly what you are doing…
Hi ,
rocketchat have not error , but I have error on egroupware-nginx container ,
roupware-nginx | 2021/11/17 22:36:03 [error] 24#24: *550 FastCGI sent in stderr: "PHP message: PHP Warning: stream_socket_client(): unable to connect to ssl://miosito.net:443 (Connection refused) in /usr/share/egroupware/swoolepush/src/Backend.php on line 198PHP message: #1 /usr/share/egroupware/swoolepush/src/Backend.php(198): stream_socket_client()PHP message: #2 /usr/share/egroupware/swoolepush/src/Backend.php(164): EGroupware\SwoolePush\Backend::http_open()PHP message: #3 /usr/share/egroupware/api/src/Json/Push.php(101): EGroupware\SwoolePush\Backend->online()PHP message: #4 [internal function]: EGroupware\Api\Json\Push::EGroupware\Api\Json{closure}()PHP message: #5 /usr/share/egroupware/api/src/Cache.php(339): call_user_func_array()PHP message: #6 /usr/share/egroupware/api/src/Cache.php(466): EGroupware\Api\Cache::getCache()PHP message: #7 /usr/share/egroupware/api/src/Json/Push.php(102): EGroupware\Api\Cache::getInstance()PHP message: #8 /usr/share/egroupware/status/src/Hooks.php(290): EGroupware\Api\Json\Push::online()PHP message: #9 /usr/share/egroupware/status/src/Hooks.php(107): EGroupware\Status\Hooks::getUsers()PHP message: #10 [internal function]: EGroupware\Status\Hooks::getStatus()PHP message: #11 /usr/share/egroupware/api/src/Hooks.php(138): call_user_func()PHP message: #12 /usr/share/egroupware/api/src/Hooks.php(82): EGroupware\Api\Hooks::single()PHP message: #13 /usr/share/egroupware/status/src/Hooks.php(43): EGroupware\Api\Hooks::process()PHP message: #14 /usr/share/egroupware/status/src/Ui.php(125): EGroupware\Status\Hooks::statusItems()PHP message: #15 /usr/share/egroupware/status/src/Ui.php(51): EGroupware\Status\Ui::getContentStatus()PHP message: #16 /usr/share/egroupware/api/src/Framework/Ajax.php(1147): EGroupware\Status\Ui->index()PHP message: #17 [internal function]: EGroupware\Api\Framework\Ajax::ajax_exec()PHP message: #18 /usr/share/egroupware/api/src/Json/Request.php(194): call_user_func_array()PHP message: #19 /usr/share/egroupware/api/src/Json/Request.php(104): EGroupware\Api\Json\Request->han
egroupware-nginx | 2021/11/17 22:36:04 [error] 24#24: *572 FastCGI sent in stderr: “PHP message: PHP Deprecated: Using a negative size to set textbox readonly. [EGroupware\Api\Etemplate\Widget\Textbox] textbox#users in /usr/share/egroupware/api/src/Etemplate/Widget/Textbox.php on line 72PHP message: PHP Deprecated: Using a negative size to set textbox readonly. [EGroupware\Api\Etemplate\Widget\Textbox] textbox#sessions in /usr/share/egroupware/api/src/Etemplate/Widget/Textbox.php on line 72PHP message: PHP Deprecated: Using a negative size to set textbox readonly. [EGroupware\Api\Etemplate\Widget\Textbox] textbox#version in /usr/share/egroupware/api/src/Etemplate/Widget/Textbox.php on line 72PHP message: PHP Deprecated: Using a negative size to set textbox readonly. [EGroupware\Api\Etemplate\Widget\Textbox] textbox#os in /usr/share/egroupware/api/src/Etemplate/Widget/Textbox.php on line 72PHP message: PHP Deprecated: Using a negative size to set textbox readonly. [EGroupware\Api\Etemplate\Widget\Textbox] textbox#php in /usr/share/egroupware/api/src/Etemplate/Widget/Textbox.php on line 72” while reading response header from upstream, client: 172.19.0.1, server: _, request: “GET /egroupware/index.php?menuaction=admin.admin_statistics.submit&ajax=false&required=true HTTP/1.1”, upstream: “fastcgi://172.19.0.4:9000”, host: “miosito.net”, referrer: "https://miosito.net/egroupware/index.php?cd=yes"
egroupware-push | receive from 11:ping,opcode:1,fin:1, users current/highest/max: 1/2/1024
egroupware-push | server: handshake success with fd12 existing sessionid=r6slou9or2f5n977qbj5m82mue
egroupware-nginx | 2021/11/17 22:37:37 [error] 24#24: *628 FastCGI sent in stderr: "PHP message:
egroupware-push | receive from 12:{“subscribe”:[“eb5c084df4a72835aaac685d36b2f93c459e8563”,“896adee5d00fe9084434c3c8ac9aeabdea0bed7b”,“8b29535dde3d8c7d7833fcdd5b2dad6b427f9a96”],“account_id”:1168},opcode:1,fin:1, users current/highest/max: 0/2/1024
egroupware-push | receive from 12:ping,opcode:1,fin:1, users current/highest/max: 1/2/1024
2021/11/17 23:08:49 [error] 24#24: *1087 FastCGI sent in stderr: "PHP message: PHP Warning: stream_socket_client(): unable to connect to ssl://miosito.net:443 (Connection refused) in /usr/share/egroupware/swoolepush/src/Backend.php on line 198PHP message: #1 /usr/share/egroupware/swoolepush/src/Backend.php(198): stream_socket_client()PHP message: #2 /usr/share/egroupware/swoolepush/src/Backend.php(164): EGroupware\SwoolePush\Backend::http_open()PHP message: #3 /usr/share/egroupware/api/src/Json/Push.php(101): EGroupware\SwoolePush\Backend->online()PHP message: #4 [internal function]: EGroupware\Api\Json\Push::EGroupware\Api\Json{closure}()PHP message: #5 /usr/share/egroupware/api/src/Cache.php(339): call_user_func_array()PHP message: #6 /usr/share/egroupware/api/src/Cache.php(466): EGroupware\Api\Cache::getCache()PHP message: #7 /usr/share/egroupware/api/src/Json/Push.php(102): EGroupware\Api\Cache::getInstance()PHP message: #8 /usr/share/egroupware/status/src/Hooks.php(290): EGroupware\Api\Json\Push::online()PHP message: #9 /usr/share/egroupware/status/src/Hooks.php(107): EGroupware\Status\Hooks::getUsers()PHP message: #10 [internal function]: EGroupware\Status\Hooks::getStatus()PHP message: #11 /usr/share/egroupware/api/src/Hooks.php(138): call_user_func()PHP message: #12 /usr/share/egroupware/api/src/Hooks.php(82): EGroupware\Api\Hooks::single()PHP message: #13 /usr/share/egroupware/status/src/Hooks.php(43): EGroupware\Api\Hooks::process()PHP message: #14 /usr/share/egroupware/status/src/Ui.php(125): EGroupware\Status\Hooks::statusItems()PHP message: #15 /usr/share/egroupware/status/src/Ui.php(51): EGroupware\Status\Ui::getContentStatus()PHP message: #16 /usr/share/egroupware/api/src/Framework/Ajax.php(1147): EGroupware\Status\Ui->index()PHP message: #17 [internal function]: EGroupware\Api\Framework\Ajax::ajax_exec()PHP message: #18 /usr/share/egroupware/api/src/Json/Request.php(194): call_user_func_array()PHP message: #19 /usr/share/egroupware/api/src/Json/Request.php(104): EGroupware\Api\Json\Request->ha
[error] 27#27: *1 connect() failed (111: Connection refused) while connecting to upstream, client: 172.19.0.1, server: _, request: “GET /egroupware/index.php?cd=yes HTTP/1.1”, upstream: “fastcgi://172.19.0.5:9000”, host: "miosito.net"
2021/11/17 22:01:06 [error] 27#27: *4 connect() failed (111: Connection refused) while connecting to upstream, client: 172.19.0.1, server: _, request: “GET /egroupware/index.php HTTP/1.1”, upstream: “fastcgi://172.19.0.5:9000”, host: "miosito.net"
2021/11/17 22:01:15 [error] 27#27: *6 connect() failed (111: Connection refused) while connecting to upstream, client: 172.19.0.1, server: _, request: “GET /egroupware/index.php HTTP/1.1”, upstream: “fastcgi://172.19.0.5:9000”, host: "miosito.net"
2021/11/17 22:01:18 [error] 27#27: *8 connect() failed (111: Connection refused) while connecting to upstream, client: 172.19.0.1, server: _, request: “GET /egroupware/index.php HTTP/1.1”, upstream: “fastcgi://172.19.0.5:9000”, host: “miosito.net
tks
