Hi dears members,
I have created a new column linked to the job_title in the admin user groups
aditor , see the image below :
http://egroupware.219119.n3.nabble.com/file/n4007544/print_function.png
I have also added this column ‘account_job_title’ in mysql database in the
table egw_accounts.
When I push the save button in the user editor it doesn’t fill the column
Where in the code php do I have to add for it works ??? I have already
modified many lines to integrate this job_title but it still doesn’t work !!
You have to add your extra column to phpgwapi/setup/tables_current.inc.php:
$phpgw_baseline = array(
‘egw_addressbook’ => array(
‘fd’ => array(
‘contact_id’ => array(‘type’ => ‘auto’,‘nullable’ => False),
‘account_job_title’ => array(‘type’ => ‘varchar’,
‘precision’ => ???)
But I would not recommend that.
Recommended way is to add a “job_title” custom field, which will be
stored in egw_addressbook_extra.
You can change our eTemplates to show that custom field in an arbitrary
position and exclude it from regular custom fields shown in an extra tab
or column.
I never have seen a so much complexe code php in my life !!
