… I can’t locate the code
from the admin.customfields.edit.
Try in egroupware/admin/inc/class.customfields.inc.php.
And another concern is how the data can be populated.
You use the custom fields widget in your eTemplate.
Study other apps (timesheet is fairly simple) to find out specifics.
It’s best if you use/extend so_sql_cf as part of your app’s storage,
as it really takes care of a lot of it for you.
Nathan
uberSVN’s rich system and user administration capabilities and model
configuration take the hassle out of deploying and managing Subversion and
the tools developers use with it. Learn more about uberSVN and get a free
download at: http://p.sf.net/sfu/wandisco-dev2dev
