Log In
</div> </div> </div> </header>
Security and Maintenance release 17.1.20180118
Announcements
EGroupwareGmbH
2018-01-18 20:14:11 UTC
#1
Changelog 17.1.20180118:
SECURITY AND MAINTENANCE RELEASE: PLEASE UPDATE IMMEDIATELY
Filemanager/Sharing: Fix a security issue when sharing of attached files as download links in compose dialog exposes all folders as readonly shares
Api: Make sure private custom fields are not accidentally included in notification due to being cached
Api: Allow private custom fields in notifications, with filtering according to set permissions. Private custom fields are removed from notifications to non-users.
Admin: Fix site-config not working in mobile template
Addressbook: Enable viewing infolog entries of organisations
Addressbook: Fix adding contact while looking at accounts would try to add a new user
Calendar: Fix bug hiding a user’s visible private events when just the group was selected
Calendar: Fix bug where account birthdays were not shown if there was a contact with a birthday on the same day
Filemanager: Fix unable to change directory after returning from shared files list
Tracker: Only allow change group context action if user has permission
Tracker: Fix missing content or doubled buttons in context menu action popups
Tracker: Fix mailhandling forward action not working
Tracker: Add start & due date fields to import
Tracker: Fix mailhandling wrongly includes original message in reply
EGroupwareGmbH
2018-01-18 20:14:37 UTC
#2
EGroupwareGmbH
2018-01-30 19:03:00 UTC
#3
