Hello,
I have an text field (Location) in database. I would like to have a
possibility to select from some options to fill this field.
So I would like to choose “selectbox” in eTemplate, and define the
values, that user will be able to select. Is it possible to define the
values, that will be available for selection, directly in eTemplate?
Old eTemplate only allows to set options in code via $sel_options
parameter of etemplate::exec().
New eTemplate2 allows additionally to specify them via template:
All
Some entries
Other entries
Android apps run on BlackBerry 10
Introducing the new BlackBerry 10.2.1 Runtime for Android apps.
Now with support for Jelly Bean, Bluetooth, Mapview and more.
Get your Android app in front of a whole new audience. Start now.
http://pubads.g.doubleclick.net/gampad/clk?id=124407151&iu=/4140/ostg.clktrk
