Hi CK,
we are currently preparing a new community release 1.6.003, with
complete PHP5.3 (not PHP6) support. It’s currently available via svn
(1.6 branch) or the daily 1.6 snapshot on www.egroupware.org/download
So far I had no problems with dl and 5.3, thought openSUSE loads the
extensions automatically, when you install them. I have mbstring
installed, as it’s required to fully support utf-8.
I suspect your provider forbids dl() - some do - or you use a multi
threaded webserver, which does not provide dl(). In Trunk we use a
special function to check and load an extension, which checks of the
existence of dl() before calling it.
I added that check now to translations class in 1.6:
http://www.egroupware.org/viewvc/egroupware?view=rev&revision=28657
Please check and report if it fixes the problem on your system.
C K Wu schrieb:
Hi, folks,
For the last two days, I had been trying to install (eGW 1.6.002 +
CK-ERP) over a new Fedora 12 environment (running the default php 5.3).
After successfully logging into the setup page, a blank page returns
instead of the usually Step 1,2,3,… page.
I traced the problem to …/phpgwapi/inc/class.translation.inc.php and
the following line (approx line 75),
==> if (extension_loaded(‘mbstring’) ||
@dl(PHP_SHLIB_PREFIX.‘mbstring.’.PHP_SHLIB_SUFFIX)) {
Changing this line to,
==> if (extension_loaded(‘mbstring’)) {
get everything back to normal, ie installation/setup completed successfully.
Accordingly to php.net,
dl — Loads a PHP extension at runtime
This function has been /DEPRECATED/ as of PHP 5.3.0 and /REMOVED/ as of
PHP 6.0.0. Relying on this feature is highly discouraged.
I don’t know if the cutting out of @dl() , may have other implications
or side effects, the development team may like to follow up on this.
I have also grepped on ‘@dl(’ and there are quite a number of places
where the dl function is being used within the 1.6.002 code base.
Because of the ‘@’ sign, the undefined dl() function error would not
even be reported in error_log. Correcting the various ‘@dl(’ 's may
solve some strange unexpected failures.
Best Regards,
CK
Join us December 9, 2009 for the Red Hat Virtual Experience,
a free event focused on virtualization and cloud computing.
Attend in-depth sessions from your desk. Your couch. Anywhere.
http://p.sf.net/sfu/redhat-sfdev2dev
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
mailto: rb@stylite.de
www.stylite.de
www.egroupware.org
Geschäftsführer Andre Keller,
Gudrun Müller, Ralf Becker
