two different errors here - as far as i see - but may be connected.
Do you get any results on your mail app?
tree and/or message list?
by the First error I assume you are getting a list, but you cannot
display content? (is that a general problem, or does it happen
only, when you are trying to open the Sieve stuff?
Morschheimer Strasse 15 | D-67292 Kirchheimbolanden
fon +49 (0)6352 . 70629-0 | fax +49 (0)6352 . 70629-30
email: kl@stylite.de Managing Directors: Andre Keller | Ralf Becker | Gudrun Mueller
VAT DE214280951 | Registered HRB 31158 Kaiserslautern
Germany
Email written with EGroupware: The software for advanced business communication
trying to change my sieve rules in trunk, I got no rules shown in my
idots template in trunk, but I got the following messages in the php
error log:
[08-May-2014 11:56:16 Europe/Berlin] PHP Warning: Invalid argument
supplied for foreach() in /usr/share/pear/Horde/Imap/Client/Socket.php
on line 2586
[08-May-2014 11:56:16 Europe/Berlin] #1
/usr/share/pear/Horde/Imap/Client/Base.php(2728):
Horde_Imap_Client_Socket->_fetch(Object(Horde_Imap_Client_Fetch_Resu
lts),
Array)
[08-May-2014 11:56:16 Europe/Berlin] #2
/usr/share/pear/Horde/Imap/Client/Base.php(2622):
Horde_Imap_Client_Base->_fetchWrapper(Object(Horde_Imap_Client_Mailb
ox),
Object(Horde_Imap_Client_Fetch_Query), Array)
[08-May-2014 11:56:16 Europe/Berlin] #3
/data1/htdocs/egw_test/emailadmin/inc/class.emailadmin_imapbase.inc.
php(3904):
Horde_Imap_Client_Base->fetch(Object(Horde_Imap_Client_Mailbox),
[08-May-2014 11:56:16 Europe/Berlin] #4
php(5010):
emailadmin_imapbase->getBodyPart(‘75633’, ‘1’, NULL, false, false, NULL)
[08-May-2014 11:56:16 Europe/Berlin] #5
php(3951):
emailadmin_imapbase->fetchPartContents(‘75633’,
Object(Horde_Mime_Part),
false, false)
[08-May-2014 11:56:16 Europe/Berlin] #6
php(4138):
emailadmin_imapbase->getTextPart(‘75633’, Object(Horde_Mime_Part),
‘always_display’, false)
[08-May-2014 11:56:16 Europe/Berlin] #7
/data1/htdocs/egw_test/mail/inc/class.mail_ui.inc.php(2661):
emailadmin_imapbase->getMessageBody(‘75633’, ‘always_display’, NULL,
NULL, false, ‘INBOX’)
[08-May-2014 11:56:16 Europe/Berlin] #8
/data1/htdocs/egw_test/mail/inc/class.mail_ui.inc.php(3312):
mail_ui->get_load_email_data(‘75633’, NULL, ‘INBOX’, NULL)
[08-May-2014 11:56:16 Europe/Berlin] #9
/data1/htdocs/egw_test/index.php(145): mail_ui->loadEmailBody()
[08-May-2014 11:56:16 Europe/Berlin] #10 {main}
[08-May-2014 11:56:16 Europe/Berlin] # Instance=default, User=kaulich,
URL=http://lenni/egw_test/index.php?menuaction=mail.mail_ui.loadEmai
lBody&_messageID=mail%3A%3A1126%3A%3A10%3A%3ASU5CT1g%3D%3A%3A75633
[08-May-2014 11:56:16 Europe/Berlin] emailadmin_imapbase::getStructure
(4768) Could not fetch structure on mail:Array Serverprofile->10
Message:Der E-Mail-Server hat einen IMAP-Fehler gemeldet.
Stack:emailadmin_imapbase->getStructure:4768 /
emailadmin_imapbase->getMessageAttachments:4794 /
mail_ui->get_load_email_data:2667 / mail_ui->loadEmailBody:3312
[08-May-2014 11:56:16 Europe/Berlin] PHP Warning: Missing argument 1 for
mail_sieve::get_rows(), called in
/data1/htdocs/egw_test/mail/inc/class.mail_sieve.inc.php on line 125
and
defined in /data1/htdocs/egw_test/mail/inc/class.mail_sieve.inc.php on
line 1079
/data1/htdocs/egw_test/mail/inc/class.mail_sieve.inc.php(125):
mail_sieve->get_rows()
/data1/htdocs/egw_test/index.php(145): mail_sieve->index()
[08-May-2014 11:56:16 Europe/Berlin] #3 {main}
URL=http://lenni/egw_test/index.php?menuaction=mail.mail_sieve.index
&ajax=true
[08-May-2014 11:58:37 Europe/Berlin] PHP Warning: Missing argument 1 for
and
line 1079
[08-May-2014 11:58:37 Europe/Berlin] #1
[08-May-2014 11:58:37 Europe/Berlin] #2
[08-May-2014 11:58:37 Europe/Berlin] #3 {main}
[08-May-2014 11:58:37 Europe/Berlin] # Instance=default, User=kaulich,
&ajax=true
Also the mailbody is empty in the preview pane.
Christoph
Is your legacy SCM system holding you back? Join Perforce May 7 to find out:
• 3 signs your SCM is hindering your productivity
• Requirements for releasing software faster
• Expert tips and advice for migrating your SCM now
http://p.sf.net/sfu/perforce
eGroupWare-developers@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/egroupware-developers
� 3 signs your SCM is hindering your productivity
� Requirements for releasing software faster
� Expert tips and advice for migrating your SCM now
