Saludos AMigos
A manera de informacion el sistema de tiques de egroupware como funciona?
Sirve para HelpDesk?
NEcesito algun modulo que instalar aparte? Gracias.
Saludos.
– Jose Alberto Pertuz GNU-Linux user #452473 Caracas,Venezuela 04141279657
Check out the new SourceForge.net Marketplace. It’s the best place to buy or sell services for just about anything Open Source. http://sourceforge.net/services/buy/index.php
Lista de correo egroupware-spanish egroupware-spanish@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/egroupware-spanish
http://www.otrs.org
Saludos AMigos A manera de informacion el sistema de tiques de egroupware como funciona? Sirve para HelpDesk? NEcesito algun modulo que instalar aparte? Gracias. Saludos. – Jose Alberto Pertuz GNU-Linux user #452473 Caracas,Venezuela 04141279657 Check out the new SourceForge.net Marketplace. It’s the best place to buy or sell services for just about anything Open Source. http://sourceforge.net/services/buy/index.php Lista de correo egroupware-spanish egroupware-spanish@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/egroupware-spanish
At times, you may end up far away from home; you may not be sure of where you belong, anymore. But home is always there… because home is not a place. It’s wherever your passion takes you. — J. Michael Straczynski
Hola.
Nosotros lo usamos de Helpdesk interno de manera muy satisfactoria.
No necesitas nada mas, los modulos basicos (adressbook, emailadmin, felamimail y tracker)
