The comments in the appdir module read as a test app. change the file name to .old at the end and hopfully egw will not read it in. appears it is not being used.
Thanks,
Randy
I created module_directory_hello in this directory:
www/system/application_name/sitemgr/ and copied the whole code of the hello
world module.
When i try to run if the module was read, at the top of the body underneath
the header, this is the error that occur:
Warning:
file_get_contents(/home/rwdevca/public_html/templates/default/module
s/appdir/list.xsl)
[function.file-get-contents]: failed to open stream: No such file or
directory in
/home/rwdevca/public_html/system/sitemgr/inc/class.xslt_transform.in
c.php
on
line 32
And why the module was not appear on the Add block…
Any help would be great.
Thanks,
Gil Poligrates
View this message in context:
http://egroupware.219119.n3.nabble.com/Site-Manager-Add-Module-tp320
7444p3207444.html
Sent from the egroupware-developers mailing list archive at Nabble.com.
Got Input? Slashdot Needs You.
Take our quick survey online. Come on, we don’t ask for help often.
Plus, you’ll get a chance to win $100 to spend on ThinkGeek.
http://p.sf.net/sfu/slashdot-survey
Randy J. Houlahan B.Sc.
Specializing in Traffic Offences
Road Warriors Paralegal Services
Tel. 1.905.641.2880 ex. 101
Fax. 1.866.841.6608
www.roadwarriors.ca
Find us on facebook
