SiteManager Installation
I tried to set up a site manager and i come up with this error on my site: Header file not found. Either your path to eGroupWare in the config.inc.php file is bad, or you have not setup eGroupWare.
I copied the directory www/system/sitemgr/sitemgr-site/ to /home/rwdevca/www.
And this is the code for my config.inc.php
$GLOBALS[‘sitemgr_info’] = array(
// add trailing slash
’egw_path’ => ‘www/sitemgr-site/’,
‘htaccess_rewrite’ => False,
This is my Site Manager Edit Website
File system path to Site Manager site directory: sitemgr/sitemgr-site
URL to Site Manager site: /system/sitemgr/sitemgr-site/
Can anyone figure out what’s wrong with my set up?
Thanks,
Gil Poligrates
/home/rwdevca/www.
Where did you put the rest of eGroupWare?
I think egw_path should point there.
Got Input? Slashdot Needs You.
Take our quick survey online. Come on, we don’t ask for help often.
Plus, you’ll get a chance to win $100 to spend on ThinkGeek.
http://p.sf.net/sfu/slashdot-survey
I changed the config.inc.php to this:
’egw_path’ => ‘/var/www/system/’, //this is where i put the rest of my eGroupWare
’htaccess_rewrite’ => False,
But this error occur when i try to access the my site:
Warning: file_exists() [function.file-exists]: open_basedir restriction in effect. File(/var/www/system/header.inc.php) is not within the allowed path(s): (/home/migrate.a2/web:/home/rwdevca:/usr/lib/php:/usr/local/lib/php:/tmp) in /home/rwdevca/public_html/sitemgr-site/index.php on line 75
Please advise.
Thanks
Yes, Nathan is correct. Your egw_peth is the path to EGroupWare. Given that /home/rwdevca/www/system/sitemgr/sitemgr-site/ your EGW_Path would be /home/rwdevca/www/system/.
Thanks,
randy
adapt your open_basedir directive then.
Restart/reload of your webserver process is needed for the changes to take effect.
kl@stylite.de
[ open style of IT ]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon 06352 . 70629-0
fax 06352 . 70629-30
www.stylite.de
Geschäftsführer: Andre Keller, Ralf Becker
USt-ID: DE214280951
Thanks Sir Randy!
How to view the site to this address http://www.rwdev.ca/ instead of this http://www.rwdev.ca/sitemgr-site/ ?
In Define Websites, I modified only the Default Website’s Site Name. I gone to Configure Website and entered value to Site name English and Generate search engine friendly URLs to Yes the Save.And when I tried to view the site in this address -> http://www.rwdev.ca/sitemgr-site/, this is the output:
THERE IS NO WEBSITE CONFIGURED FOR URL http://www.rwdev.ca/sitemgr-site/ (default). NOTIFY THE ADMINISTRATOR.
Please advise.
Thanks
I have recently encounter that even though the default anonomous user is give permission to the “website” it still is denied. I re-saved the password as “anonomous” and presto.
When you get a chance you should double check the default pass for the anon user sitemgr creates (upon install) and ensure it matches the default in the define websites screen. Report back your findings here if they differ. otherwise … ensure the sitemanager user’s pass matches the password defined in the define sites section of the sitemgr.
thanks,
randy
