Anyway, it is could be similar to phpbrain.
Cheers,
István
----------------eredeti üzenet-----------------
Feladó: "Pongrácz István"
Címzett: eGroupWare-developers@lists.sourceforge.net
Dátum: Fri, 11 Sep 2009 22:30:52 +0200
Are there any existing solution to show address-book entries determined by
category(ies)?
For example, show categories from the addressbook selected by the top-level
category and if I click on the category, it shows all addressbook entries
under that selected category?
Thank you!
István
trial. Simplify your report design, integration and deployment - and focus
on
