Hi everyone,
I’m trying to test upgrade my installation from 17.1 to 19.1 on ubuntu 20.04
I installed 19.1 over of 17.1, everything seems to work fine except the websites created by sitemgr.
Sitemgr is still in place in /usr/share/egroupware after upgrade.
I had first to create symlink for the header.inc.php file to solve this
Header file not found. Either your path to eGroupWare in the config.inc.php file is bad, or you have not setup eGroupWare.
When I try to open the website, I niow got a blank page.
Apache logs give this error :
PHP Fatal error: require_once (): Failed opening required ‘/usr/share/egroupware/api/src/Session.php’ (include_path = ‘.: / Usr / share / php’) in /var/www/index.php on line 93
on my installation, website works with a copy of sitemgr-site in /var/www
Any help would be very appreciated
Alexandre
